Weird Voltage Fluctuation Under Boost?
Old Sep 2, 2006 | 12:14 PM
EVOlutionary's Avatar
Hi All -
Just a couple quick questions. Have any of you ever seen a voltage fluctuation under boost when you are logging? If so, what was the problem or what did you do to fix it?
Here is my scenario: we were logging some EMS parameters while doing dyno runs. On almost every run once the engine got to about 5000 or 6000 RPMs the smooth voltage line would start to fluctuate rapidly beween about 12-13 volts (might have been 12.5-13.5 volts). It looked like it went from a fairly flat line to what looked almost like a sine wave, up and down, up and down.
You could also see a bit of a flicker in all of the dash and accessory lights - they would dim and brighten repeatedly.
Battery? Alternator? ECU? Ignition? Loose ground? Any ideas where to start?
Thanks!
EVOlutionary
Old Sep 2, 2006 | 01:20 PM
Forgot to mention - this happened with both a COP ignition (AEM box) and with the stock coils running off the new Sun Auto ignition box.
Old Sep 3, 2006 | 10:36 AM
Anyone? What can I test?
Old Sep 3, 2006 | 09:42 PM
Drifto's Avatar
Maybe the belt is slipping? Is it old?
Old Sep 4, 2006 | 07:59 AM
I am assuming you are talking about the belt to the alternator? The car has 50K miles on it. Could the belt slip in a rhythmic pulsing manner to cause the described fluctuation?
Old Sep 23, 2006 | 09:08 AM
bump for ideas. . .
Old Mar 8, 2020 | 12:36 AM
Adriank's Avatar
Originally Posted by EVOlutionary
bump for ideas. . .
did you ever find out the problem to this? Having the same problem now, voltage is jumping from like 12.8-13.6 or so under WOT which is causing afr oscillation.
Old Mar 8, 2020 | 10:31 AM
No I don’t t think so. I switched tuners and then sold the car and built a new “06 the following spring. Post up if you track down the issue.
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
Raceghost
Sep 28, 2016 01:20 PM
dredman1
Lancer Troubleshooting
Sep 12, 2015 10:06 AM
Raptord
Oct 23, 2013 06:46 PM
