Installed a catback...
Old Sep 2, 2006 | 12:40 PM
willum14pb's Avatar
Installed a catback...(help!)
So I installed the AMS catback on the car but when the car is cold what happens is that I hear this creaking noise(like metal on metal or a bad door hinge) from where I think is the cat converter and the midpipe. I placed new gaskets there so is this supposed to be normal for a "break in" or something? This only happens between the 1k to 2k rev range, when you start the car, and only when the actual exhaust pipe is decently cold, after a hard pull the sounds completely go away I assume because they heated up. Maybe I screwed the lugs in too hard as well? There are also no exhaust leaks as I have tested so far. Help please!
Old Sep 2, 2006 | 04:56 PM
willum14pb's Avatar
Anyone have any tips to lead me to the right direction?
Old Sep 2, 2006 | 05:20 PM
boostedwrx's Avatar
Probably just a heatshield rattling. Get under there and look at it though, try to move it around a little bit. You'll be able to tell what it is. If done correctly you shouldn't hear anything except for the new exhaust tone.
Old Sep 3, 2006 | 12:39 PM
highpsievo8's Avatar
wd-40 on exhaust hangers
drisn
Sep 11, 2015 05:08 AM
4DOORGALLOR
Mar 11, 2010 02:16 PM
SpeedI2acerX
Feb 9, 2009 03:38 PM
SilverEvoX
Aug 20, 2008 12:21 PM
DEBAUCHERY
Aug 7, 2008 05:24 PM
