Intake manifold explosion! Alcohol possible cause?
Well, after 3 years of abuse my Magnus Motorsports sheet metal intake manifold exploded!
I mean that quite literally. I was driving home from work Friday morning, and got on it in 1st gear. Just as I was shifting to 2nd I heard a pop and figured I just bumped the rev limiter on the shift.... but the revs hit the limiter and stayed there..... I hit the gas pedal and let off (figuring it was a stuck throttle) and when that didn't work I shut off the car and pulled over. Feeling around under the hood (5:30 AM, pitch black) I couldn't find anything wrong with the throttle body, so I felt around a bit more and found that the intake manifold was compleatly destroyed!
I wonder if running methanol injection into an aluminum sheet metal intake may have been a contributing factor? I was running 30 psi and had never heard of this happening for anyone running less than 40 psi of boost.
Now the good news. I called Dave at Buschur Racing and he overnighted a ported stock manifold to me. I installed it yesterday and the car is once again drivable. The injector O-rings (into the manifold, not the small ones at the fuel rail) are shot, so I will not be doing any "high performance" driving untill next Friday when I can get a chance to replace them... but at least the car is drivable back and forth to work in the mean time.
Later,
Keith
Later,
Keith
just happened to see this intake, looks a bit prettier.
http://motors.search.ebay.com/_W0QQs...Q5fengineering
why were you still getting fuel when you took your foot of the throttle? was the throttle cable misconfigured ?
The throttle prevents air from entering the engine..... that is it's one and only purpose, to control the amount of air entering the engine. If your intake manifold explods there is nothing preventing air from entering the engine.
Keith
Keith
Hmm I highly doubt that it was the meth, shepherd has been running a AMS VSR manifold on Straight methanol for a while now. It seems like magnus has a new design for the evo8 now maybe they had this problem too?? I vote bad welds
Originally Posted by nothere
yes but the throttle position sensor will suggest to the ecu what fuel should be injected no?
Keith
