Numbers Too Low?
Old Sep 10, 2006 | 08:27 AM
Varrius's Avatar
With similar mods, I pulled 322awhp and 331awtq on a mustang. That's normal, right? Or were mine too low, also?
Old Sep 10, 2006 | 08:30 AM
Varrius's Avatar
Btw, I have these mods Downpipe, Test pipe, Cat Back, Walboro 255, Hallman MBC @ 25 PSI, EcuTek. Intake
I don't have the "just added list", but I do have LICP, which was added AFTER the tune. My torque was pretty good, I was happy. My tuner says the MIVEC has to kick in when the turbo goes to spool, or something. It's not easy to make a good mivec map, he said. But you'll know if you have a good one when you have a lot of torque. Being that 9s are very new it's likely that their isn't really much experimentation with the MIVEC and bigger turbo's. Which probably contributes to your mediocre numbers.
Old Sep 10, 2006 | 11:00 AM
EVOlutionary's Avatar
Normal.
EVOlutionary
Old Sep 10, 2006 | 11:03 AM
Originally Posted by mikerobave
So i just completed a whole bunch of mods (see the second half of my sig) and after the reflash and dyno, i was a little disappointed in my numbers. Well, i thought id get some more HP but my TQ numbers seem really low for the amount i have into this project. Any ideas, suggestions, comments. SMC alcohol in in the near future but im just wonderin how much thats actualy gonna do wit TQ numbers this low. Thanks guys.
At first I thought that looked way low, but then I realized those were graphs of straight pump gas. On pump gas I think that is a very appropriate HP and TQ. Once you start adding bigger turbos and raising your top end powerband HP goes up much faster than TQ.
As others said, on race gas or pump+methanol you will be impressed by the numbers and performance.
EVOlutionary
Old Sep 10, 2006 | 07:52 PM
mrdevo's Avatar
Originally Posted by Soon2BEVO
he has an MR... 6 speed tho. not 5
Thought 1st thru 3rd were nearly identical. If it was a 6 speed and the dyno was done in 4th, the mph would read at least 100 to equal 7000 rpms and 110mph for almost 8000rpms. It looks like the dyno was done in 3rd gear based on the mph readings on the graph, so it almost looks as if the turbo is falling off towards redline.
Old Sep 10, 2006 | 07:56 PM
scorke's Avatar
Those numbers are bang on, on pump gas I made the same hp but 360 tq, on race I made 490 480.
Scorke
Old Sep 10, 2006 | 08:06 PM
Soon2BEVO's Avatar
Doesnt seem to be falling that bad at all to be honest IMO. I hate how Turbotrix uses the damn MPH instead of RPM. Just use RPM god damn it LOL.
Old Sep 11, 2006 | 01:33 AM
Ang Wen Yan's Avatar
For comparison sake... can anyone find other IX's with upgraded turbos such as 3076 or 50trims?
AMS just did one.477whp with 50 Trim,JUN 264 cam,reflashed stock ECU with consertive tune.
Old Sep 11, 2006 | 07:07 AM
Soon2BEVO's Avatar
I should have said "on straight pump". Also, that guy has an exhaust cam. I was basically trying to show that an IX with upgraded turbo but without cams wont make the power of an VIII with cams and upgraded turbo.
