left front tire coated with black substance
Old Sep 11, 2006 | 04:48 PM
MooneyDriver's Avatar
left front tire shock coated with black substance
I was rotating the tires on my 06 Evo MR with 5800 miles and the front left Billstein shock was totally covered in a black coating. Did not think much until I saw that the other three are bright yellow.
I will pull the wheel again tomorrow and look at it, but wonder if anyone can tell me what is on that side that can cause that kind of leak, gear, trans axle, ...?
Thanks guys.
Old Sep 11, 2006 | 04:50 PM
ak47po's Avatar
Is it dry or oily?
Old Sep 11, 2006 | 04:51 PM
Yes it was pretty dry and caked on.
Old Sep 11, 2006 | 04:56 PM
ak47po's Avatar
Probably just brake dust.
Old Sep 11, 2006 | 06:03 PM
RazorLab's Avatar
That's undercoating. Mine where like that too. One was bright yellow, other was covered in the undercoating.
Old Sep 12, 2006 | 05:23 AM
You know it looked pretty thick. I can believe that it is undercoating. Did you remove it or leave it on the shock?
Old Sep 12, 2006 | 05:49 AM
Steve_P's Avatar
I just cleaned the undercoating off mine last nite. Yuck, what a mess. Paint thinner and lots of paper towels will do it. Won't harm the yellow paint either.
Old Sep 12, 2006 | 10:45 AM
will try to clean with thinner...
Thanks Steve_P and razorlab. I will do so tonight...
Old Sep 12, 2006 | 11:02 AM
DRFTKNGG's Avatar
USE some gunk degreaser, works great. I sprayed on, power washed off.
Old Nov 9, 2006 | 01:17 PM
Yeap it was undercoating washed it off now I am happy again. Thanks for the help.
Old Nov 9, 2006 | 02:24 PM
freshevo8's Avatar
i would still check your outter cv boot on the axle. something on the road could've cut the boot open and threw grease everywhere. its just one of those better safe than sorry. if you don't catch it quick, your going to be paying for a new axle instead of a cv boot. jack the car up on the side you found the substance and do a quick check of the cv boot and make sure theres no cuts on the boot.
