Pressure @ Fuel Rail
Old Sep 14, 2006 | 07:07 PM
djd24's Avatar
Does anyone know what the pressure at the fuel rail is on a stock Evo 8?
Old Sep 14, 2006 | 09:00 PM
barneyb's Avatar
33 psi at idle
Old Sep 15, 2006 | 08:04 AM
djd24's Avatar
Thanks. How high will it get at redline under full boost?
Old Sep 15, 2006 | 09:14 AM
Ted B's Avatar
The fuel pressure will rise at a ratio of 1:1 with boost pressure. This is done so that no matter what the boost pressure, the difference between the fuel pressure and manifold pressure will always be the same.
Old Sep 15, 2006 | 11:14 AM
djd24's Avatar
Thanks. So you're saying that at 20psi i should be seeing around 53psi of fuel pressure?
Old Sep 15, 2006 | 12:08 PM
Ev0ikon's Avatar
Thumbs up
You are pretty good at math!
Old Sep 15, 2006 | 01:19 PM
djd24's Avatar
I know!...and...I didn't use a calculator
Old Dec 16, 2006 | 06:00 AM
1badgsex's Avatar
is that 33 that same for a evo 9
Old Dec 16, 2006 | 12:41 PM
SwiftEVO's Avatar
Actually it should be 43psi. At idle your pulling a vacuum so the pressure will be less. So if you running 20psi then your running 63 pounds of fuel pressure.
--Josh
Old Dec 16, 2006 | 12:53 PM
stevoviii8's Avatar
disconnect the vacuum line to the fuel regulator. you should see 3 bar fuel pressure.you disconnect the vacuum so that there are no external influences on the regulator .
vipevo9
Aug 21, 2017 06:44 PM
Jovan Caro
Feb 21, 2017 11:39 AM
Jovan Caro
Feb 8, 2017 06:59 PM
MisUnderStood
31
Nov 30, 2016 03:18 AM
Black_EVO_MR
Oct 30, 2016 07:18 AM
