Losing Boost on Evo 6 - Help!
Old Sep 17, 2006 | 05:18 AM
sherif_e1's Avatar
Hi all
I am having a problem with boost pressure cutting out at 5000 rpm from 3rd gear onwards... I am running an Evo 6 on stock turbo at 1.1 Bar and have done nothing to the car since the problem started except stick HKS plugs on there...
My boost contoller stopped functioning (also a week ago when i tried to reset low/high pressure) as well and I am holding steady at 1.1 bar whether I switch between low/high boost or switch the controller off altogether.
I checked air filter to make sure its clean, looked checked BOV to make sure I wasnt losing pressure there, replaced a leaky boost gauge for a new Greddy gauge, but I still cant see to isolate the problem.
Any recommendations here would be greatly appreciated.
Old Sep 18, 2006 | 03:13 AM
Ang Wen Yan's Avatar
Do a boost leak test.Boost leak test is a must on FI car.
Old Sep 18, 2006 | 04:46 AM
sherif_e1's Avatar
I will try that tonight, but after doing some research on the web, I am starting to think it maybe related to fuel cut out... I cannot seem to isolate the problem.
I am getting a modified turbo, fuel regulator and bored fuel rail installed tonight so lets see if this fixes the problem after I run a boost leak test.
Thanks - I will let you know if it is indeed a leak.
mrfred
383
Jul 16, 2024 09:29 PM
Mellon Racing
16
Feb 11, 2008 01:16 PM
sherif41119
Nov 27, 2006 10:07 AM
