6 spd MR tranny weaker than 5 spd?
Nissan s15 six speed trannies are known to be weaker than 5 speeds in s13 and s14's.....so I figured Id see what you guys had to say about the MR's gearbox.
Greg
Greg
Originally Posted by EVOL EDO
the answer is yes, and search, 4th gear goes out on a lot of the 6 speeds
https://www.evolutionm.net/forums/sh...d.php?t=210221
The 6 speed is more prone to overheating on road courses (25 minute + sessions). The fluid to heats up, stops working and 4th gear is usually the first to go. It's not really an issue on a drag strip or on the street though, since it's very unlikely you'll heat the trans up nearly as much.
If you're going to track the car a lot, get the 5 speed.
Originally Posted by xspsi4
Getrag is usally a good tranny builder.
3rd gear on up is very weak in the 6spd, here is 4th:
6spd:
1st = 19mm
2nd = 19mm
3rd = 16mm
4th = 14mm
5th = 14mm
6th = 14mm
5spd:
1st = 14mm
2nd = 17mm
3rd = 19mm
4th = 18mm
5th = 18mm
I wouldn't call 3rd in the 6spd beefy but it isn't as small as 4th +
1st = 19mm
2nd = 19mm
3rd = 16mm
4th = 14mm
5th = 14mm
6th = 14mm
5spd:
1st = 14mm
2nd = 17mm
3rd = 19mm
4th = 18mm
5th = 18mm
4th gear and up. 3rd is beefy, isn't it?
Even with it's apparent weaknesses; the 6 speed should be able to hold up just fine for most of the people who left the car stock and only attack a freeway off ramp every now and then.... and I'm sure that when Mitsubishi approved the 6 speed they didn't think that us turbo crazed people would take the EVO as far as we did. At least they kept the 5 speed around.
I wish Mitsubishi made the 6speed like this...
1 through 4 is SAME as 5spd.
5th gear CLOSER to 4th (5spd guys know how crappy 5th is) and
6th gear for highway cruising and gas mileage. Man that would make me happy.
Technically, can you install 5spd gears in the 6spd tranny like that.. and get a custom 6th gear hehe
Originally Posted by razorlab
6spd:
1st = 19mm
2nd = 19mm
3rd = 16mm
4th = 14mm
5th = 14mm
6th = 14mm
5spd:
1st = 14mm
2nd = 17mm
3rd = 19mm
4th = 18mm
5th = 18mm
1st = 19mm
2nd = 19mm
3rd = 16mm
4th = 14mm
5th = 14mm
6th = 14mm
5spd:
1st = 14mm
2nd = 17mm
3rd = 19mm
4th = 18mm
5th = 18mm
