Manley I beam rods
Old Sep 19, 2006 | 07:00 AM
funnyclub's Avatar
Manley I beam rods
Hey guys just wondering does anyone have experience with these rods.
They are rated to 1000bhp+. I am hoping to use them in my stroker engine running a gt35r just want to make sure they are up for the job I realise they are rated to 1000bhp but you never know.
Let me know what you guys think.
Old Sep 19, 2006 | 07:22 AM
Gary C's Avatar
Product Line: Manley Pro Series I-Beam Connecting Rods
Connecting Rod Length Center To Center (in): 6.635 in.
Connecting Rod Beam Style: I-beam
Connecting Rod Material: Forged 4340 steel
Connecting Rod Finish: Shot-peened
Wrist Pin Style: Floating
Clearanced for Stroker: Yes
Cap Retention Style: Cap screw
Connecting Rod Bolt Brand: ARP
Connecting Rod Bolt Diameter: 7/16 in.
Connecting Rod Bolt Material: ARP 2000 alloy
Fastener Yield Strength (psi): 220,000 psi
Connecting Rod Bolt Head Style: 12-point
Pressurized Pin Oiling: No
Approximate Connecting Rod Weight (g): 830
Big End Bore Diameter (in): 2.325 in.
Pin End Bore Diameter (in): 0.991 in.
Big End Width (in): 0.990 in.
Pin End Width (in): 1.125 in.
Advertised Horsepower Rating (hp): 900 hp
Advertised RPM Rating: 8,000 rpm
Weight Matched Set: No
Remanufactured: No
Balanced: No
Magnafluxed: Yes
Old Sep 19, 2006 | 08:05 AM
Her GSX's Avatar
Registered User
I've never heard of anyone having an problems with Manley rods. They make great products. I also purchased Manley rods for my 2.3 stroker. I plan on running a FP 3065 or possibly a GT35R also.
This is wrong. All of their rods are weight matched.
Old Sep 19, 2006 | 08:52 AM
Noogles's Avatar
If your looking for 1000hp or 10k rpm just go with the Carrillo H-beam, you'll never break it and they have the strongest robbolts in the market.
I saw a carillo rod push a wrist pin through a JE piston when the motor hydrolocked, nothing happened to the rod it was still within carillo's specs.
Old Sep 19, 2006 | 09:10 AM
funnyclub's Avatar
They will only be for a 2.3 running a gt35r so I wont be reving it over 7500rpm, so they should hold up fine.
Old Sep 19, 2006 | 09:46 AM
Bom's Evo's Avatar
manley's are turbo tuff.
Old Sep 19, 2006 | 11:42 AM
Gary C's Avatar
I agree Carrillos are very strong but are a little heaver.
Old Sep 19, 2006 | 12:05 PM
Noogles's Avatar
The carrillo H beam rod only weighs 567 grams
Old Sep 19, 2006 | 12:08 PM
Aby@MIL.SPEC's Avatar
carillo h-beams are compariable in weight, while the a-beams are some of the lightest out there.
if your looking to make a 1000 hp, dont skimp.
Old Sep 19, 2006 | 12:22 PM
EFIxMR's Avatar
the A beam carrillo is not very strong.
Old Sep 19, 2006 | 12:30 PM
Noogles's Avatar
Still stronger than an Eagle but definately weaker than a Crower or Pauter rod
Old Sep 19, 2006 | 01:53 PM
funnyclub's Avatar
Abit off topic there guys I am asking about Manley I beams.
Should they cope on a 2.3 with a ams gt35r.
Old Sep 19, 2006 | 01:55 PM
1.8t's Avatar
How do oliver rods fair in the strength category?
Old Sep 19, 2006 | 02:34 PM
Noogles's Avatar
If you want to keep it in the 600whp range and under 7500 rpm you can use eagle rods without a problem.
Oliver makes a very good rod, but for the 4g series motor i would onLy use Carillo or Pauter
Old Sep 19, 2006 | 02:35 PM
thetox's Avatar
OT: My vote goes towards 35R....when we putting in the stroker?
