Walbro Fuel pump
Old Sep 27, 2006 | 02:21 PM
03silevo's Avatar
Walbro Fuel pump
Is there any way at all to test the walbro fuel pump to see if it is goin bad.....when im cruising at a steady rpm in 3rd 4th and 5th grs i happen to get a spuddder like a hestation seems like im not getting fuel......when it first happens i get the good ole p0300 code and my afr goes REAL LEAN past 17.0......so i have a feeling it is my fuel pump is there any way at all to test to see if that is goin bad or not?
Old Sep 27, 2006 | 02:34 PM
gsrboi80's Avatar
Could be spark related as well. How old are the plugs in the car and what are they gapped to if copper
Old Sep 27, 2006 | 02:37 PM
03silevo's Avatar
oh belive me i have elimnated the plugs lol.....i have changed them back and forth from the bpr7es to the bpr8es......finally im back to the 8's gapped at .026....just so i make sure its not a spark issue and if it was spark issue i think that i would run a little bit more rich not lean thanks though
Old Sep 27, 2006 | 02:45 PM
gsrboi80's Avatar
Yea depending on the gap. Do you have your stock pump. Its a quick way to find out if you Warlbro is breaking up on you.
Old Sep 27, 2006 | 02:47 PM
PVD04's Avatar
I have the same thing happen when I get my PO300, but I assumed it was related to the ECU going into some sort of safe mode due to the code. As soon as I lift off the throttle and reapply it the problem goes away. I don't seem to have any problems with fuel at WOT so it seems that my fuel pump must be working well.
-Paul
gsrboi80's Avatar
But yea your right if your spark was breaking up it would be dumping fuel.
Old Sep 27, 2006 | 03:03 PM
03silevo's Avatar
-Paul
yeah thats tru but the only thing is once it start happening it keeps doin it repeatedly......but i mean i can drive for a month and it not happen but when it does happen everytime i was in 5th gr not in boost everytime i would hit like 5000 rpms it would happen.....the only way i could get past 5000 rpms i had to get into boost real real real odd that is why im beginning to think its the walbro
