stock biss screw setting.....
does anyone know what the stock biss screw setting is??? Or was it set from the factory specific to each vehicle coming off the line? oh yeah I have an '04
thanks
thanks
BISS = base idle speed screw. It trims the air getting past the throttle plate so that the ISC (Idle Speed Control) stepper motor doesn't run out of travel. If the stepper motor runs out of travel (the BISS isn't set correctly) the engine may die or surge at idle.
To adjust the BISS you need the MUT tool, which I feel is ridiculous. I can't see driving the 100 miles to the nearest dealer to just set my idle. Some smart person needs to come up with a work-around for this.
Raceghost
25
Jan 27, 2017 03:20 PM
audiofan
Aug 14, 2016 08:47 PM
Raceghost
Jun 7, 2016 08:06 PM
