grind going into 2nd gear
Old Oct 7, 2006 | 12:38 AM
  #31
pao's Avatar
pao
My evo 9 mr does the same thing in 2nd even though the clutch is pressed all the way down. It does so probably 1/6 of the time i go into 2nd gear. I noticed it a little after putting 600 miles on the car, took it to the dealer's shop and they quoted it as "gating" and is normal on some evo's for about the first 1k miles.
The car has about 2.4k miles on it and the problem isn't apparent anymore, but on the ocassion, I can't get into 1st gear. Pumping the clutch a few times solves the problem though....or so i think...
Old Oct 7, 2006 | 12:42 AM
  #32
joseph143's Avatar
Originally Posted by SP00LIN
If by "you", you mean you wish show everyone on the boards how smart you are and that you didn't even need to go to college to get so educated, then by all means - knock yourself out.
If by "you", you mean me - then go f yourself you condescending b1tch.
Ladies can we all just get along here. we are here to help out one another not call each other names like we're in kindergarden.
yes the tranny has syncros to help downshift. So no techinally you dont need to rev match. But obviously the stock synchros arent perfect as seen by how many people have had to replace them. So take everyones advice and apply it if you want if you dont then we well be seeing your thread on "My synchros are bad" here shortly
Old Oct 8, 2006 | 10:02 PM
  #33
sonicnofadz's Avatar
Actually I'm a computer engineer/mechanical engineer from University of Maryland (college park). I'm not trying to be to patronize you at all. You don't need to resort to name calling either, which is pretty pointless on an internet forum. Just google "rev matching" (use the quotes), and check out of the very first result you find, and it will clearly explain the many benefits of baby'ing your transmission.
Old Oct 25, 2006 | 09:43 AM
  #34
Jer.k's Avatar
I've also been having this problem ever since my break-in period was over...if I shift 2nd too fast at around redline it will grind every time ...so far the only things I've tried is adjusting my shifting slower, which helps when I'm thinking about it(I've had this same quick shifting technique w/ my previous 5 spds,honda subaru).... and just yesterday I tried to adjust the clutch pedal up to engage quicker but didn't help in the least. I guess I'm to the point where I want to know if the problem is me or my cars 2nd gear syncro, or clutch, or stock flywheel, or clutch restrictor line??
I wanted to bring this back up because there seems to be more people w/ the same problem and want to know how to fix it.
Old Oct 25, 2006 | 09:58 AM
  #35
evo150's Avatar
people have been having good luck with installing a front motor mount insert to solve there high rpm shift grind. search front motor mount
Old Oct 25, 2006 | 10:28 AM
  #36
AfireINSIDE's Avatar
First I removed the clutch line restrictor made shifting quicker and at that same time I did a SS clutch line this gave me a much harder more responsive clutch pedal. I then changed tranny fluid pennzoil helped normal driving notchyness and difficulty getting the car into 5th and reverse, then did the front motor mount eliminated the high rpm grind completly, and while I was at it i did the under hood bushings made shifts more accurate. Thats on a 04 8
Old Oct 25, 2006 | 11:51 AM
  #37
Try adjusting the shifter cable linkage.
Old Oct 25, 2006 | 12:31 PM
  #38
Jer.k's Avatar
http://www.lancer-evo.net/community/...pic.php?t=1871
This is interesting...seems to explain exactly what I think is happening to my quick 1-2 shift.
Old Oct 25, 2006 | 12:35 PM
  #39
Jer.k's Avatar
I'll have to look into this too
Originally Posted by franc01
I don't know how the Evo shifter linkage is set up, but on my previous DSM (fwd turbo Laser), there was a fix for a resistant shifter which involved taking off the front/back and side/side linkage from the shifter cable end links and readjusting it until the ends slipped into the shafts on the shifter itself with no resistance. Then you'd go out and drive, stopping every once in a while to adjust the ends of the linkage at the shifter. Eventually, I got my car to not only shift smoother, but my second gear grind disappeared! Again, I haven't looked at the Evo linkage but I think that if it is similar to the DSMs, it may be worth a try.
Take care,
Franc
Old Oct 25, 2006 | 01:30 PM
  #40
j3ffw19's Avatar
sonicnofadz do you happen to drive a bby evo with the tein sticker on the rocker panel, if so i have seen you around laurel. not to many evos around my neck of the woods though. Would be nice to hang out with fellow evo owners once in awhile.
Old Oct 25, 2006 | 02:39 PM
  #41
Nope that wasn't me, I drive a Silver Evo8 with an STIkiller.com rear license plate. Most of the time I drive a beat down green Toyota Paseo =)
Old Oct 25, 2006 | 02:56 PM
  #42
Actually, it turns out there is no way to adjust the shifter linkage (to my knowledge) on the Evo...however there is a clip that you should check to see if it has excessive play:
PriusRepellent
Sep 18, 2015 05:39 PM
av00va
Sep 14, 2014 04:19 PM
Evv007
May 27, 2014 06:27 AM
smanders
11
Apr 9, 2010 04:34 AM
Erikos
28
Mar 12, 2010 11:11 AM
