Length of T Belt Tensioner
Old Oct 2, 2006 | 03:15 PM
whitey4d's Avatar
Length of T Belt Tensioner Tool
Hey guys. I know some of you already have a T Belt tensioner tools. I have all materials to make my own I just didnt know how long it is? I know DSM guys made them out of there battery tie down bolt. I would do that but I relocated my battery yrs ago and no longer have that bolt. SO whats the length of the rod tip tip. Thanks Alot.
AdamR
Old Oct 3, 2006 | 08:13 AM
whitey4d's Avatar
Bump for answer... need asap
Old Oct 3, 2006 | 09:53 AM
whitey4d's Avatar
No one knows how long the T Belt tensioner tool is?
Old Oct 3, 2006 | 01:14 PM
Steve_P's Avatar
I don't have it handy, but IIRC 6" is long enough- but I'd go a little bit longer to be safe. 8" will be plenty. I made one from a piece of class 8.8 or 10.9 all thread and two nuts butted against each other- don't use cheap threaded rod. Grind the threads down on the first half inch to the minor diameter and add a spherical radius on the end.
And for others, don't use the battery hold down bolt- it's a very soft steel. You will have a problem removing it when the threads screw up.
Edit: I measured the one I made and it's 6.5".
Old Oct 3, 2006 | 03:50 PM
whitey4d's Avatar
Sweet thanks man for the reply I have some 8.8 grade all thread with two nuts to lock them together.
Old Oct 3, 2006 | 04:41 PM
dubbleugly01's Avatar
8" long with 3" worth of thread. Don't go cheap here..... if it breaks, it's gonna cost you big.
Old Oct 4, 2006 | 06:11 AM
althemean's Avatar
I think AMS sells it for $35. Put some antiseize on the threads as well. Thats how I combat the sticky thread problem.
NZevolution5
Jul 4, 2013 10:27 AM
keithrybicki
Lancer Troubleshooting
Aug 1, 2011 07:27 PM
mfr122887
Mar 18, 2008 01:32 PM
Boost3dxEvO
Nov 13, 2007 11:43 AM
Cajun Power
Feb 2, 2004 02:01 PM
