Balance shaft belt tension?
Old Sep 26, 2012 | 11:56 PM
NZevolution5's Avatar
Hey,
Have searched but came back with no result, Anyone know how tight the balance shaft belt should be? My belt seemed to be reasonably slack in tension when I removed it in my evo 5.
Any help would be much appreciated,
Thanks
Old Sep 29, 2012 | 09:34 PM
I-5 Evo's Avatar
Well at least it wasn't overtightened like mine was. I ended up breaking mine on the track which resulted in buying all new valves.
Originally Posted by NZevolution5
Hey,
Have searched but came back with no result, Anyone know how tight the balance shaft should be? My belt seemed to be reasonably slack in tension when I removed it in my evo 5.
Thanks
Old Sep 29, 2012 | 10:41 PM
barneyb's Avatar
The service manual for my 8 reads that when properly tensioned the T belt should deflect 0.20 to 0.27 inches with a finger pressure of 22 pounds. So, have your finger calibrated.
Old Oct 1, 2012 | 12:19 AM
haha yea, would be pretty hard to give the belt 22 pounds of pressure with you finger, anything in your service manual on the tension of the balance shaft belt?
Old Oct 1, 2012 | 09:37 AM
murderedout's Avatar
I would get the balancer belt delete kit. I had the balancer belt snap, which f*&%ed my timing belt dropping valves. Only good thing it finally gave me the motivation to build the engine
Old Oct 1, 2012 | 06:46 PM
barneyb's Avatar
My bad, that into is for the balance belt.
Old Jul 4, 2013 | 10:27 AM
krazykorean84's Avatar
So as the service manual says the balance shaft belt should have 22lbs of tension, how is everyone checking this tension when replacing the belt? Just guesstimating with "finger" tension or is there a tool that folks are using?
Not looking to spend money on a balance shaft delete kit yet. Just need to change my belts for 60K mile service.
RussellM
22
Jul 26, 2025 09:02 AM
alexc
Jun 16, 2015 11:20 AM
Henrys Ralliart
63
Mar 17, 2012 07:17 PM
tim85851
11
Dec 10, 2011 09:42 PM
4doorbullit
Mar 18, 2010 06:37 PM
