GSC 280's installed with dynosheets
Old Oct 12, 2006 | 11:03 AM
EvO6-RS2's Avatar
Originally Posted by mrdevo
...The light green would be the gsc correct?
Yep, light green is the GSC...they make more power & torque
Old Oct 12, 2006 | 02:50 PM
GregGSC's Avatar
Originally Posted by EvO6-RS2
Greg,
I checked my plugs lastnight, they looked PERFECT, so I don't think it was fouling, i'm currently using a gap of .22.
You suggest I try and use a larger gap .28 or .26? I was actually thinking to go smaller/tighter to .20.
Also, i'm wondering if my plug wires might be going bad as breakin up is sometimes a symptom of bad wires.
.22 is super low in my book. how ever other than a stock ecu and an AEM EMS i dont have any experiance with the Autronic box to know. what plugs are you running?
Old Oct 12, 2006 | 10:10 PM
EvO6-RS2's Avatar
I'm running NGK BR8ES...my Autronic is very similar to an AEM. Let me know what you think on the plug gaps?
Old Oct 13, 2006 | 02:49 AM
ONRAILS's Avatar
Can you guys post the lift numbers on these cams. I'm considering getting these or the comp 280's. However i'd like to know the lift.
Old Oct 13, 2006 | 07:07 AM
EvO6-RS2's Avatar
Spec's included with cam for GSC 280's
lift = 10.32
Total Duration = 288
1mm to 1mm Duration = 218
The key to this cam is duration, not lift, as per Greg @ GSC. The increased duration gives more power & more torque with much better idle as well vs. increased lift.
Old Oct 19, 2006 | 01:50 AM
BlownIncome's Avatar
Nice numbers...I may purchase a set of these to compliment my new turbo kit (Apexi rx6). I'm currently running autronic's but will probably switch back to my ecu with a custom flash. Is there anyone out there running these with a flashed ecu?
Old Oct 19, 2006 | 02:21 AM
04WWRS's Avatar
I am. Just got mine installed yesterday. Flash will be no problem.
Old Oct 19, 2006 | 07:23 AM
EvO6-RS2's Avatar
My car now idles so much better with these cams vs. my HKS 264/272's...it much smoother & steadier.
Now I run a leaner idle mixture 13's at idle (before I had to idle at 11.5 ish AFR's anything leaner my cars rpm would start to hunt between 1000-1200 rpm).
Should be OK with a flash, I forsee no problems.
Old Oct 19, 2006 | 08:31 AM
GregGSC's Avatar
Have you tried to add timing to the top end yet? you should be able to run a couple more degree's with ours over the hks units. by all means watch your knock but as for an average you should be good to go.
Thanks for the post btw customer feed back is always appreciated.
Old Oct 19, 2006 | 08:49 AM
gaulrich2003's Avatar
Thumbs up
I am about to switch my HKS cams on my already tuned car to buy these bad boys. You can’t beat the low cost of these cams for such high horsepower and torque gains.
Old Oct 19, 2006 | 09:19 AM
3deep's Avatar
Swap out your plugs,water and meth=plug killers.Also i wouldnt go any lower then .24-.25 with a good set of plugs.
Old Oct 19, 2006 | 09:53 AM
EvO6-RS2's Avatar
Gonna try a wider gap and try get on the dyno again this weekend.
Old Oct 19, 2006 | 09:58 AM
EvO6-RS2's Avatar
I think my tuner was able to add more timing in the top-end and throughtout the entire rpm range. Car still needs some fine tuning once the breakin-up, mis-fire issue has been corrected, but it runs awesome now at 22psi
Old Oct 19, 2006 | 07:31 PM
blowoffsilver's Avatar
what kind of plug wires are you running, and the stock ones made 500whp for me with a dli.
Old Oct 19, 2006 | 07:39 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
when i made 568 awhp on stock motor besides gsc 272s and headstuds on meth/pump gas i was runnin .18 to keep my totally stock ignition from breaking up and it still wasn't happy
