Stock PSI on a 2006 IX ?
Old Nov 17, 2006 | 02:00 AM
Bosshog's Avatar
how is your boost curve?
Mine spikes to 26psi, holds around 24.6psi through 4 - 5.5k RPM and drops to 20.5-21psi at 8k RPM. Boost is controlled via ecutek (restrictor pill removed). Car was mapped with shell v-power (97ron) but I run shell v-power racing (100ron) for additional safety when available
Originally Posted by evo-mike
max boost is 20.5 on an off the showroom floor ix. the ix brochure says exactly, to 2 decimals. so if people dont believe u, just show them the brochure. available at any dealership. like some of the others said, it will spike, depending on the car and mods, 2 psi or so. for u it will probably spike to ~22psi. and again like the others said it will taper. tapering means the boost pressure fades/falls at higher rpms. the taper varies, some fall as low as 15psi, typical is ~18psi near redline. i recommend getting a good boost gauge so u can see for yourself. the ix is a bamf. it can hold more boost i stock form...i dont recommend adjusting boost for someone like yourself. take it to a professional tuner who works with evos. ie: al at dynoflash or similar. feel free to ask any other questions. btw: my ix holds 25psi, but is tuned and has fuel considerations.
Old Nov 17, 2006 | 07:39 AM
Warrtalon's Avatar
Boss, have you verified that you actually see 26psi with no boost control through the use of a MAP sensor? It's very hard to get your boost that high with no boost control, and just removing the pill gives very erratic boost - not the best idea when you could easily have full control over the boost with a simple boost controller...
Old Nov 17, 2006 | 07:54 AM
evoNine's Avatar
hmm, mine boosts at 16-17 pounds, completely stock too, dunno what it is prolly the crappy autometer boost gauge i have, lol
Old Nov 17, 2006 | 08:02 AM
Warrtalon's Avatar
Stock is 20.3psi at 3500rpm, tapering to 17psi by 6500rpm (use 3rd gear as your reference). Some IXs boost more or less due to whatever differences there may be between cars, but those numbers above are the listed standard from Mitsu.
Old Aug 20, 2007 | 08:19 PM
striderx88's Avatar
wow
Old Aug 20, 2007 | 09:05 PM
shuttlegoose's Avatar
mine usually spikes to around 20 and holds around 17 18ish, im using a prosport electronic boost gauge
Old Aug 20, 2007 | 11:14 PM
XSivPSI's Avatar
Who makes an accurate boost gauge? Both my prosport electronic gauge and my autometer mechanical gauges are off by atleast 1psi, maybe more.
Old Aug 21, 2007 | 12:22 AM
ranz's Avatar
as i can understand that stock evo boosts approx. 20psi and how much hp will it give at this boost??
Old Aug 21, 2007 | 12:26 AM
4Trouble's Avatar
97 RON ~ 92 MON (what they use in the states)
100 RON ~ 94 MON
Isn't 24.6psi with 26psi spike a little high for the gas you're running?
Old Aug 21, 2007 | 12:35 AM
bboypuertoroc's Avatar
Veteran: Army
Read your owner's manual... it states it very clearly.
Old Aug 21, 2007 | 12:45 AM
Kdash106's Avatar
when my car was stock, it pushed 1.2-1.1 max. maybe is because i live in Colorado too.
Old Aug 21, 2007 | 12:51 AM
ranz's Avatar
how many horsepowers it output at 20psi?
Old Aug 21, 2007 | 06:26 AM
TTP Engineering's Avatar
Zeitronix wideband with kavlico medical grade pressure transducer (MAP sensor) is the most accurate.
Old Aug 21, 2007 | 01:07 PM
XSivPSI's Avatar
Thanks, I'm running the zeitronix wb on my eclipse. I'll look into that.
Old Aug 21, 2007 | 01:17 PM
Mr. Evo IX's Avatar
Originally Posted by evo ippo
are you asking stock boost pressure or pressure off the wastegate, because sometime the boost control is not working then it reacts off the wastegate only
Wastgate pressure on a IX is ~11psi. I think it cracks around 8.. but it will boost to 11psi with the turbo connected to the wastegate. The boost on the IX is mechanically limited to around 20psi by the 2 boost "orfaces" or pills if you will. 1 is located about 2 inches from the boost solenoid and the other is after the pill in the middle of the small hose that runs to the turbo off of the Tee.
The stock Tee that the boost gauge runs off of also has an orfice in it as well.
