LM-1 Rpm voltage?
Old Oct 18, 2006 | 10:42 PM
xLaNcErEvOx's Avatar
LM-1 Rpm voltage?
Just starting on the lm-1 and I just need to know how to convert the volts to rpm...
Old Oct 18, 2006 | 11:01 PM
RoadSpike's Avatar
Since its not stated do you have a lma-2 rpm converter kit or the lma-3 aux box.
Since rpm's are measured by ignition pulses these are supposed to do the calculation for you, or so i thought..
Old Oct 18, 2006 | 11:51 PM
i have the lma-2 rpm converter. not sure if i did the setup on the RPMconverter correctly. at around 850 rpm on the tach, the log shows .22 volts. When i try to setup to show RPM instead of volts, the rpms are way off.
Old Oct 18, 2006 | 11:53 PM
btw, i did a direct connection from the ecu for the rpm readings, i didnt have an induction clamp.
Old Oct 18, 2006 | 11:56 PM
RoadSpike's Avatar
I pulled out the LMA-2 manual and read it for you
According to chaper 5.2
http://www.innovatemotorsports.com/s...MA2_Manual.pdf
The steps are:
-Connect and power up the LM-1 and RPM-Converter as described in Chapter 4.
- Make sure the Indicator LED is lighting up steadily at 2000 RPM.
- Press and hold the Setup button on the RPM
- Converter until the Indicator LED on the RPMConverter blinks rapidly.
- You have now 10 seconds to rev up your engine to 2000 RPM while the Indicator LED blinks rapidly.
- Hold the engine at 2000 RPM ( +- 200 RPM) while the Indicator LED blinks. When it starts to blink slowly it is taking measurements.
- After a total of 15 seconds the Indicator LED will light up steadily.
- Relax, you are done.
If you need chapter 4 here you go:
4. Using the RPM-Converter with pulsed RPM input (Tach) signals
- Unplug the inductive clamp from the RPM converter if connected.
- Connect the RPM signal to the RPM pulse input screw terminal.
- Plug the RPM-converter into the LM-1 unit.
- Start the engine.
- Switch on the LM-1 unit.
The indicator LED on the RPM-converter should light up steadily. The indicator light indicates
when a valid rpm signal is detected. If it does not light up, check your connections.
DO NOT CONNECT A PULSED RPM SIGNAL TO THE INDUCTIVE CLAMP INPUT. THIS
MIGHT DAMAGE THE RPM-CONVERTER OR LM-1. Again, this should just result in an
error code, not mechanical damage.
In most cases the ground connection of the RPM converter is required only if the other Aux
Inputs (2-5) are
EDIT:
Best of luck
Old Oct 18, 2006 | 11:59 PM
ill try that rev to 2000 thing, and thanks for the help. if it doesnt work then ill be back.
Old Oct 19, 2006 | 12:02 AM
RoadSpike's Avatar
You could try reading the manual yourself you know
Old Oct 19, 2006 | 12:05 AM
me no english...
jbergmeier
Mar 2, 2009 05:57 PM
Mr. Evo IX
Mar 5, 2008 10:22 AM
gosu.pianist
Feb 21, 2008 06:16 PM
nj1266
Jul 7, 2007 08:39 PM
xLaNcErEvOx
Jan 31, 2007 09:55 PM
