Forge MBC tapering...
Old Nov 10, 2006 | 08:26 PM
Warrtalon's Avatar
Originally Posted by qazsz
I have IX with k&n drop in filter. i just put in the forge mbc with soft spring. i was wondering if it was normal to spike at 20 psi and then taper to 15 (this was after ~25 clicks). i will be putting on a tbe pretty soon and then i will do the mail in flash from dynoflash. do you think it would be able to spike 21psi and have less taper than what im getting now? or should i try changing the spring? I have the mbc connected to the wastegate and the turbo outlet.
edit: i jsut found out that i still that little pill in the stock turbo outlet tubing. could this be why its tapering so much. the instructions i read in the how-to section didnt say anything about that little pill. i just used the new tubing that came with the mbc. should i put it back onto the new tubing?
You should be using fresh hoses with no restrictor pills when using an MBC. The pills are for the ECU to regulate boost.
Old Nov 10, 2006 | 08:49 PM
qazsz's Avatar
oh ok. what do you think about my tapering issue. do you think its normal. i was doing some pulls in third gear up to ~6k rpm. im using the stock mr guages and its spiking at 1.4bar and then tapers to 1.1. what do you think?
Old Nov 10, 2006 | 09:01 PM
Warrtalon's Avatar
Yes, it's normal. Plus, you can't rely on regular boost gauges to determine your actual boost - you have to log it with a MAP sensor of your own or on a dyno.
Old Nov 10, 2006 | 09:37 PM
tlclee's Avatar
My Evo 8 was able to hold boost from 1.5 taper to 1.3ish with Apexi AVRC. My Evo 9 is boosting with a Hallman from 24 psi tapering to 17 or so. It prob need an upgrade wastegate to hold more boost.
Tom
Old Nov 10, 2006 | 10:07 PM
Warrtalon's Avatar
No, it doesn't need an upgraded wastegate, because it's not tapering because of the wastegate - the turbo is unable to keep pace with the head. You can force the boost to not drop as much with a Forge IX WGA or with an EBC with tweaked settings, but then you're just forcing it to blow hot air unless you use something to cool the intake charge (e.g. alky).
People need worry less about their perceived "boost taper" and focus MORE on their performance. I think it has become a stigma where people don't know anything else about their car, but they sure can watch that boost gauge, so if their boost tapers, then it must be bad!! It's not necessarily bad. Go see if it loses power on the dyno or runs crappy at the track.
Old Nov 11, 2006 | 05:51 PM
steevo's Avatar
Good advise. I used to be one of those people, but after talking to my tuner and reading all the related threads, I know the stock turbo will taper. I swear though, my forge tapered less than my hallman pro. I put it on the dyno dynamics dyno for the first time and have proof it spikes to 22psi and tapers to 15psi by redline. My forge held really good in third gear. I was suprized at the amount of taper with the hallman, but atleast I understand why now. It's not the mbc. My butt dyno still argues with me about it though.
Edit: Just checked my log, and it does not taper to 15psi, it tapers to 17psi at 7400rpm. The taper really begins at 5700rpm.
Old Nov 11, 2006 | 06:43 PM
Warrtalon's Avatar
Well, why did you change to a Hallman if your Forge was doing so well? If it held more boost as proven by a MAP sensor, then put it back on...
Old Nov 11, 2006 | 06:54 PM
andifidie's Avatar
+1
Old Nov 11, 2006 | 07:02 PM
2theMAX's Avatar
So what determines if you run the stiffer spring or not?
Edit: This is answered in the other thread.
Old Nov 12, 2006 | 05:13 AM
steevo's Avatar
My nob was stuck on my forge, and my shop only had hallman's in stock. After it was installed, I told my tuner how much more the hallman tapered. He said that what I was describing was practically impossible. I kind of argued, then put it on the dyno to get the map of the hallman. I'm definately going to get another forge and put it on the dyno to see the difference. I wil post the results. I do know one thing without the MAP sensor. ...my forge never tapered to 15 or 16psi on my guage. I know that for sure, and hope it's the same on the dyno.
Old Nov 12, 2006 | 07:26 AM
Warrtalon's Avatar
Ah, the stuck knob. That was very weird.
Old Nov 12, 2006 | 10:49 AM
vwjeff's Avatar
+1... what the h*ll is this spring for?
Old Nov 12, 2006 | 10:54 AM
andifidie's Avatar
As production of the Forge UNOS MBC has been running, the spring rates have some "change" from batch to batch. Depending on if you have a newer or older UNOS the spring you would use would be different. I am using the soft spring on a 1 month old UNOS and it holds 23(spike) psi all day long. I believe older modle ones use the stiff spring. Try both, and whatever one holds your boost better is the one you want Just remember to start low and bring boost up a few clicks at a time to prevent possible overboost conditions.
Old Nov 12, 2006 | 10:56 AM
andifidie's Avatar
+ 1 for Killlswitch Engage, new album is awesome
Old Nov 12, 2006 | 11:02 AM
EvoDan2004's Avatar
i dont want to cause a problem here but my forge parts are great.
stock i was boosting 19psi tappering to almost 16psi. i put the mbc on and i set it to boost at 21psi and it tappers to just a lil over 18 psi. i then put my wga in and a tune and i spike 24 hood 22 and im holding HOLDING 20 at redline in 3and 4 gears. 5th i dont hit redline offen but say at 6100 rpm im holding 21 ish. id say at redline i would be at 20.
i tested my boost gauge and i tested the gauge i regulate how much psi it is showing. there bouth dead on. tapper will always happen yes but some do see more then others.
