Forge MBC tapering...
Old Feb 12, 2007 | 07:24 PM
  #61
anjapower's Avatar
which spring should be used for 22-24psi?
Old Feb 12, 2007 | 07:33 PM
  #62
TTP Engineering's Avatar
Soft spring will suffice.
Hard spring will boost 24-26psi minimum spike at the controller's lowest setting.
BTW: That is the most ridiculous statement I have ever heard in your sig. I don't know whether to laugh at it or just shake my head.
Old Feb 12, 2007 | 07:40 PM
  #63
anjapower's Avatar
Thanks for the input, Scott.
I share your sentiments on the quoted material in the sig
Old Feb 14, 2007 | 07:59 AM
  #64
TURBODAWG's Avatar
ALL YOU EVO IX USERS WILL HAVE SUBSTANTIAL TAPER NO MATTER WHAT.
Unless you get a Electronic Boost controller that will Eliminate the taper. We have tuned 2 Evo 9's now that will hit 22 psi peak and hold 22 psi to 7500 RPM. One had a stock actuator, one had a Forged upgraded actuator. Same results both cars. The EVC 6 has capabilities to eliminate taper up to 21 to 22 psi on the Evo 9's with stock turbos and stock actuators. You just have to know how to set it up.
With stock boost control or a MBC, your statement above is correct 100%.
Brian
Old Feb 14, 2007 | 08:37 AM
  #65
There is no boost controller able to eliminate taper with high performance MIVEC mapping in the ECU.
Old Feb 14, 2007 | 09:21 AM
  #66
TURBODAWG's Avatar
Wanna bet??
EvoIxRick
Sep 21, 2013 12:55 PM
Evo_Jay
26
May 27, 2007 03:24 PM
fxyxixe
12
Mar 21, 2007 03:03 PM
coolguycooz
Sep 30, 2006 11:03 PM
Trojan man
21
Nov 4, 2005 07:25 PM
