rebuilding motor, need parts list
Old Oct 24, 2006 | 11:37 AM
Evo_SpeedKing's Avatar
ok so due to a damaged piston or fried rings i have to rebuild my motor, of course i won't be doing the work! i'm having a hell of a time finding a long block so i am just going to start buying the parts i need. i want it done right, something that can handle alot of power... what do i need?
ps, i'm not looking to make this a "---- pistons are better than ____ pistons" or "XXX tuner beats YYY tuners parts!" just what parts i need.
Old Oct 24, 2006 | 11:42 AM
boostinjuice's Avatar
https://www.evolutionm.net/forums/sh...hreadid=226996
Old Oct 24, 2006 | 11:47 AM
jmartinez1170's Avatar
Hey man just pm me im rebuilding my car this is my second rebuild ill tell you all you need i dont feel like typeing a long post because people will turn it into a part fest.
And you dont have to buy a long block it will cost you less to just bore out your block.
Pm me for info
Old Oct 24, 2006 | 12:05 PM
boostinjuice...yeah, thats me talking to Martin about it...
J...i was looking for a long block to minimize my down time as this car is my daily driver.
Old Oct 24, 2006 | 12:12 PM
RaNGVR-4's Avatar
pistons, rods, crank, main and rod bearings, ARP rod and main bolts and head studs, MLS mitsu headgasket, Balance shaft removal kit, engine gasket and seal kit, new water pump, new oil pump, new Timing belt and tensioner, and you might want to do the clutch while you are in there. i dont think im forgetting anything... god knows ive done it enough
Old Oct 24, 2006 | 01:26 PM
Ry, can't i just reuse my crank?
Old Oct 24, 2006 | 01:31 PM
RoadSpike's Avatar
You can but you wanted to handle "alot of power" the stock crank is good for like what 500-600hp? If you wanted to go higher safely why risk other components?
EDIT: gah i was thinking rods... a crank isn't a bad way to go for insurance purposes.
Old Oct 24, 2006 | 02:49 PM
RaNGVR-4's Avatar
you can reuse your stock crank for sure. unless you are wanting above 600 whp. then its a bit sketch. the machine show would probably just polish it and youd be good to go.
Old Oct 24, 2006 | 04:35 PM
good, cause a new crank (eagle 88mm) is $800!!!! i'm sure a polish is far less... i've got a price list, give me a min and i'll post it.
