Boost problem!!
Originally Posted by ace_2822
I searched, Most with that problem are running mbc. Can you manually move the rod for the wastegate,? Mine seems kinda stiff.
The overboost code means exactly that, your ecm has detected higher than "normal" level of boost running. Maybe your wastegate is sticky mine had some rust becuase of the heat so i put some anti stick , its like a powdered nickel coat in liquid form, on it and it seems to move a little better.
