MBC installed. Having trouble now. Help please.
Old Oct 27, 2006 | 12:22 AM
TogueMonster's Avatar
How can you doubt that's the problem when you haven't done a boost leak test and the LICP is the most common cause of boost leaks? It does not matter how hard you tighten it or what clamps you use - if there is a kink, or a bad angle, or anything, there can be a leak. I cannot see how you'd conclude that because you had no boost leaks before the install of the LICP that you would have none now...
Cuz I'm smoove like that. Just fixed it. The white/red wire from the ECU that I tapped into for the HKS EIDS came apart. Rewired it, soldered it, and taped it up. Runs like Ben Johnson on performance enhancing drugs. Was pullin a P0102 code on account of the MAF plug. Fixed and done, I rule.
Old Oct 27, 2006 | 12:24 AM
1) That's the worst MBC for the Evo. Sell it (if you can) and get a Forge UNOS or Hallman Pro.
2) LICP installations are the most common culprits for boost leaks. It doesn't have to pop off to be leaking. You need to doublecheck the installation, but more importantly, do a boost leak test.
3) Before doing anything, switch the boost system back to stock using the OEM BOOST LINES, and see if the boost issue is still there.
4) Did you say you are SURE there are no boost leaks just because you installed t-clamps? Come on, dude, you don't know a durn thing until you do a boost leak test. Just installing t-clamps ensures nothing. Do a proper boost leak test: http://vfaq.com/mods/ICtester.html
5) Poor choice of BOV (much like the MBC)
6) You still have the stock intake. Are you still using the stock intake snorkel that feeds air to the aribox? If so, does it still have both clips holding it down? If not, that's a big problem, so get 2 replacement clips from the trunk lining.
7) I use the turbo nipple for my MBC install, but the BOV method works fine if you do it right.
0 for 7
Old Oct 27, 2006 | 12:35 AM
Laxman's Avatar
What about a Turbosmart or a Perrin MBC? Anyone try one of those?
Old Oct 27, 2006 | 12:54 AM
Evo8zip's Avatar
so was your MAF unplugged or what?? either way i was 1 for 1
Old Oct 27, 2006 | 01:07 AM
Not really unplugged, just disconnected, which is really the same thing. So yeah, 1 for 1, high five! Thanks.
Nasty Evolution
13
Feb 19, 2010 07:27 PM
bboy_RES
32
Jun 18, 2009 02:26 PM
Jon91TSi
Jul 19, 2007 05:17 PM
drewblueeye
56
Sep 26, 2006 08:09 AM
osunick
May 6, 2005 06:39 AM
