Could have this been affecting power?
Old Oct 27, 2006 | 06:25 AM
EVIL_EVO_VIII's Avatar
So last night i got home from work and decided to take the airbox out and a couple things and readjust everything to make sure everything was tight.. I noticed that the nipple under the elbow that goes to the turbo wasnt capped off... I capped it off last night and took the car for a couple of runs on my way to work this morning... I did feel the turbo spool a bit quicker and a little more torque....
Was this really affecting me? Its been like this the whole time... Opinions please
Old Oct 27, 2006 | 06:35 AM
Benja's Avatar
If the nipple was part of the turbo-->t/b piping then being a leak it would of course affect things slightly.
Thats where this nipple is yeah?
Old Oct 27, 2006 | 06:38 AM
cfdfireman1's Avatar
"nipple under the elbow that goes to the turbo"
Are you talking about the turbo outlet? Either way yes it will make a difference.
Old Oct 27, 2006 | 06:45 AM
Im talking about the rubber elbow from the airbox that goes to the turbo, not the outlet pipe...
Old Oct 27, 2006 | 07:21 AM
bump!
Old Oct 27, 2006 | 07:30 AM
spdracerut's Avatar
if there's any sort of leak after the MAF, yes, it'll affect power.
Old Oct 27, 2006 | 07:41 AM
justchil's Avatar
Yes.. it would allow unmetered air in... I'm not sure how significant the loss would be.. but the answer is yes as stated above.
Old Oct 27, 2006 | 07:47 AM
Thanks for the responses guys!
Old Oct 27, 2006 | 08:04 AM
AlwaysinBoost's Avatar
if that nipple wasn't capped off, or connected to the breather hose like it should be, you were letting in unmetered air. It will make your car run leaner which could actually make you faster depending on your tune
Old Oct 27, 2006 | 08:16 AM
well the car runs better now, feels like turbo spools faster
Old Oct 27, 2006 | 08:31 AM
dubbleugly01's Avatar
if it's the tiny little nipple used for the stock boost control soleniod return, it's a non issue. That thing is probably only allowing about as much unmetered air into your system as your manual boost control is bleeding off. The two would cancel each other out.
Old Oct 27, 2006 | 08:43 AM
no its not that one.. Its the one under the rubber elbow from the airbox to the turbo
Old Oct 27, 2006 | 01:22 PM
PcK EvO's Avatar
i noticed that even on my injen intake piping its a very small opening kinda stickin out......i always wondered what it was for......im guessin a cap would be better?
Old Oct 27, 2006 | 01:37 PM
joeymia's Avatar
it would make a very very very very very very very very tiny difference. I doubt you would even notice...
Old Oct 27, 2006 | 01:42 PM
I actually did notice a difference... Faster spool than before it was uncapped
