Engine Problem... please help
Old Nov 1, 2006 | 11:28 AM
ripnet's Avatar
Question Engine Problem... please help
Hey guys, I searched with no luck.
I am having two problems, idk if related or not.
1st: The car idles like crap when its cold. It idles fine when warmed up.
2nd: At 0.5bar of boost, the car starts to spudder and start to run lean (about 14.5 - 15.0). I was thinking maybe MAF or FPR but I'm not sure.
Also, where can I even get a MAF besides the dealership who just tried to screw me for another $400?
Thanks,
Tom
Old Nov 1, 2006 | 12:05 PM
Warrtalon's Avatar
Have you checked and/or changed your plugs? Why would you suspect your MAF or FPR? Did you damage them or something?
If I had to get a MAF, I'd get one used form someone who did a big turbo upgrade with AEM EMS.
Old Nov 1, 2006 | 01:03 PM
ripnet's Avatar
I suspect my MAF because I've had some problems with it before. I cleaned it and it solved some of my low idling problems, but soon after that problem this one started.
Also something to note: I can rev all the way up to redline if I wanted w/o problems, it's only when I hit 0.5bar of boost that it does this.
Thanks
Old Nov 1, 2006 | 01:21 PM
Kee1pride's Avatar
isn't there something on the intake manifold or t/b that can move your idle up and down?
Old Nov 4, 2006 | 07:15 AM
ripnet's Avatar
Yeah. There is. But that doesn't solve my running lean under higher boost.
Any other ideas?
Thanks
Old Nov 4, 2006 | 07:25 AM
AndyBandy's Avatar
do you have a custom tune or something? are you running like 87 octane? (i had to ask)
