Post clutch install problems
Old Nov 3, 2006 | 08:38 AM
bboypuertoroc's Avatar
Veteran: Army
Well, me and some buddies just got done installing my clutch and flywheel last night... took it for a 2 mile test drive to make sure everything was good, let it sit and run for a little and checked for leaks, checked torque specs (or so I thought) etc. After that I start my ~8 mile drive home. Everything is going fine until I start hearing a faint click coming from under the car... which goes away after a few seconds. I come to a light, and while slowing down, I hear the clicking again. Now I'm pretty curious what this sound is. I'm only about 2 miles from my house, so I decide to take it home and park it so I can check it out the next morning. Well, about another mile and the clicking comes back... which is then followed by a slight vibration. First thing that came to mind was a motor mount not being tightened down correctly. Well, about a 1/4 mile later, the ticking came back, which was followed by a much angrier vibration, which felt like it was coming from directly beneath my seat. It came in "rotations", and was getting worse. When I slowed down it would go away. So I keep it around 15mph, which seemed to be working, but it came back. STRONG. I'm hearing noises now like bolts hitting stuff... no bueno. I pull over and look under the car... there happens to be a single 12mm IIRC bolt with a black painted head lying under the car. I try my best to find where it came from but no luck. I looked under the hood to see if my motor mount bolts were in place which to the best of my knowledge they were. I eventually get the car home which is accompanied by plenty of vibrations and clicking sounds.
The vibrations seem to come on when I let off the gas or when I got above 1500 rpms. When I first get on the gas they go away, but come back withing about 10-15 seconds. My guess would be it has something to do with the driveshaft not being torqued down somewhere. What are you guys' guesses? TIA.
Old Nov 3, 2006 | 11:02 AM
C6C6CH3vo's Avatar
Trying to remember where a black painted 12mm bolt was at. I just finished same job,
Old Nov 3, 2006 | 12:41 PM
Veteran: Army
Thanks... I'm lifting her back up when I get off of work (it's only 1040 out here), just trying to get a good idea where to go first.
Old Nov 3, 2006 | 04:43 PM
Veteran: Army
Anyone?
Old Nov 3, 2006 | 05:21 PM
EVO9MRNJ's Avatar
good luck figuring it out post some picks and what you find intrested!
Old Nov 3, 2006 | 05:55 PM
Evoryder's Avatar
good luck with it.
Been awhile since i did my clutch...was on an 8 though? maybe your acd?
Old Nov 3, 2006 | 08:47 PM
Veteran: Army
Found it... it was the driveshaft bolts... they weren't torqued down. Lucky for me, one of the bolts held, and I found one of them when I pulled over. Now it's off to the hardware store to find some replacements. I knew I shoulda triple-checked everything.
Tony (can't trust no one!)
Old Nov 4, 2006 | 02:55 AM
C6C6CH3vo's Avatar
Thats why I did it myself. I could have used help lifting her back in there though
Good you found it, I remember those where black but I couldn't figure why those needed removing
Old Nov 4, 2006 | 05:54 AM
4ringturncoat's Avatar
They musta tried to drop the tc rather then just getting it out of the way.
Old Feb 12, 2007 | 10:28 AM
o.e.boost's Avatar
i had a problem and i posted a separate post but one of the problems that occured was the tob or something on the engaging assemble to tick!!!...anybody experinced this
Olms2468
May 14, 2015 05:48 AM
rgar
24
Nov 10, 2010 12:46 PM
MTRJunior
39
Apr 18, 2009 02:12 AM
drewblueeye
Jun 15, 2007 08:50 PM
Matz
Apr 15, 2007 03:18 PM
