engine vibration problem
Old May 12, 2015 | 11:24 AM
Olms2468's Avatar
As of recently. I have started to get a weird vibration around 2200 rpm. It's not a constant rpm and if it's under load the vibration doesn't really happen. I get the vibration if I rev the car when in neutral, when the rpms drop in between shifts, and under slow deceleration. It starting happening soon after a shop built a custom top mount turbo setup. The noise went away when my wastegate got repositioned after an incident with the radiator...lol. then the wastegate clamp came lose Rotated down , and took a chunk out of my radiator again. I then rotated the wastegate again and the vibration came back. Now when I rev the car now I can see the wastegate tube from the manifold and wastegate vibrate and make the noise. the tube for the wastegate is not cracked or anything.
I do not have balance shafts and I do have an exedy twin disk. I have been told the exedy twin can cause some vibrations. What does everyone think
Old May 12, 2015 | 01:10 PM
Ev0ikon's Avatar
Clutch would not have caused the vibration. Most likely it because of the MISSING BALANCE SHAFT.
LetsGetThisDone's Avatar
Are you complaining about a vibration, or a noise?
Your'e going to get harmonic vibrations because you don't have balance shafts.
Old May 12, 2015 | 01:24 PM
Olms2468's Avatar
It'sboth actually. I know I'm going to get more harmonic vibration. I'm just double checking everything to make sure it's not something terrible. I kind of figured it was because of the balance shaft delete. I'm going to have the shop weld a brace on that wastegate tube to stop it
Old May 12, 2015 | 05:38 PM
Olms2468's Avatar
So I'm not sure if it matters. I am running a fluidamper crank pully. A local guy was saying that it could be that. It's been on the car for a couple years. Anyone have this issue? I am going to put the stock one back on this weekend and see what happened. It's only the tube to the wastegate and the wastegate that vibrate
Old May 13, 2015 | 09:24 AM
Ev0ikon's Avatar
That fluidampr part should help reducing the vibration - not to add to it.
I assume your wastegate and the tube to it is a v-band, correct? Your brand may be worn and should be replaced if it's allowing your gate to rotate.
Old May 14, 2015 | 05:48 AM
Olms2468's Avatar
no. The v band was not tight enough so it came loose on a long trip and rotated down. After I cranked it down really good, it stayed and has stayed.
RED DEMON
18
Jul 27, 2015 06:38 PM
elhuberto
Sep 13, 2013 04:45 PM
KillaItalian904
Oct 9, 2007 06:49 AM
cetinsaya
May 20, 2007 12:53 PM
fifty1fifty
16
Jan 26, 2005 03:59 PM
