tapping sound
Old Nov 4, 2006 | 09:27 AM
EVO MR FU's Avatar
tapping sound
Pruven installed my hks 264/272 cams
Most threads I read aBout tapping is when engine is at idle
Mine doesn't really tap when at idle
it taps if I rev up to 1500-2000 rpm , is this a lifter causing it also?
thanks
Old Nov 4, 2006 | 09:41 AM
4Gsixty3's Avatar
yes. mine tap at idle and when i rev it to 2k rpm.
Old Nov 4, 2006 | 09:46 AM
EVO MR FU's Avatar
so is this just as bad? how do I get rid of it if it isnt good for the car??
Old Nov 4, 2006 | 10:38 AM
jrsimon27's Avatar
did you bleed the lifters??
you must bleed them!
Old Nov 4, 2006 | 10:55 AM
EVO MR FU's Avatar
Pruven peformance installed my cams, so I dont know if they bled them. Anyone else had their cams installed at pruven??
Old Nov 4, 2006 | 11:16 AM
tony gibson's Avatar
No but the ticking is just annoying...the car is not going to break or prematurley wear out.
Old Nov 4, 2006 | 12:04 PM
EVO MR FU's Avatar
Ok, I mean I dont mind the ticking b/c its only at very low rpm but as long as it isn't bad for the car. It would be a pain in the *** to get it reinstalled.
I just thought if it was the lifters it was bad for the car?
Old Nov 4, 2006 | 12:06 PM
k270kmh's Avatar
My engine with stock cams makes this tap noise between 1500 to 2000rpm.
I do not know if it is a lifter or a thin oil or a normal noise on the 4G63
Old Nov 4, 2006 | 01:56 PM
ONRAILS's Avatar
the 4g63 is really noisey.. Evo motors are a lot better than the dsm's though
Old Nov 6, 2006 | 12:30 PM
EVO MR FU's Avatar
I dont mind the noise, just that the sound wasn't there with the stock cams
