eBay O2 housing = brings the torque
Old Nov 5, 2006 | 11:17 AM
VRamirez2004's Avatar
How hard is it to install the 02 housing im debating to buy 1??
Old Nov 5, 2006 | 11:20 AM
boostingevo8's Avatar
It's not too hard if you have mechanical knowledge of the evo somewhat...
There is a great DIY in the HOW TO SECTION.
Peace
Old Nov 5, 2006 | 11:24 AM
jhanksevo's Avatar
it is actually easy for both. I noticed a big difference once mine was installed I dont have any #'s but it pulls hella harder. Also I did my boost controller too. Mods are in my sig
RenoEvo's Avatar
so spectre were all three cars running catless?
Old Nov 5, 2006 | 05:35 PM
-=SPECTRE=-'s Avatar
Originally Posted by spyderx
on my 04, I'd pick up 337whp but it much laggier w/ the SS O2. I am not sure if I'd do it again...
My car hits peak torque at 3500-3600rpm so it hasn't impacted my spool at all. Maybe mivec makes a difference?
The answer depends on whether or not you work for the government..
Old Nov 5, 2006 | 05:50 PM
spyderx's Avatar
funny guy^
good to see evos in Atlanta area, where about are you guys?
Old Nov 5, 2006 | 06:16 PM
Sgt Blamo's Avatar
O2 housing & MR header are worth 22 peak HP and 17 ft lbs TQ when combined. Most of the TQ occurs in the low-mid range.
Here's a link to ebay for a good FMIC, this is identical to the one I bought.
http://cgi.ebay.com/ebaymotors/3-Cor...mZ230037375467
You will need to buy two 3"-2.5" reducers to install it. It fits perfectly with the stock piping, but requires some fabricating if you have the Injen intake like I do.
Here's another one that will install even easier, just a tad smaller:
http://cgi.ebay.com/ebaymotors/FMIC-...QQihZ013QQitem
Z230046123566
The same vendor also sells the uglier AMS looking one. Remember, he will bargain down $10-15 off his price!
I'm also posting a most excellent link for all your silicone piping, joiners, T-bolts, etc. best prices I've seen yet.
http://www.siliconeintakes.com/
Old Nov 5, 2006 | 09:28 PM
TTP Engineering's Avatar
Originally Posted by -=SPECTRE=-
TTP did a great initial road tune on a very hot day in Orlando. TopSpeed did some tweaks today to correct some dips in the graphs, correct a slight lean condition at spool and get some more power out of the car.
Stock programming for the ECU has lean spoolup. The additional heat spools up the turbo more quickly.
Old Nov 5, 2006 | 09:58 PM
Jeff_Jeske's Avatar
Very true. Vishnu runs 12.0:1 at spool on pump. You can get away with this because the timing is fairly low at that point.
As for the O2 housing, I did my 10.5HS separate from the O2. The HS was much more noticable than the O2 housing. I have since gone back to the stock O2 housing and I didn't notice a difference either way.
I'm not so sure the ebay O2 makes much of a difference. So far the only dyno of O2 housing alone was an improvement only due to increased boost. So if you like to run high boost on pump gas, it may help you out a little, but those results are only from one test vehicle.
Congrats on your nice strong pull. I wonder how much of a difference the difference in gearing between the 8 and 9 affects the HP numbers.
GST Motorsports
Dec 22, 2010 12:37 PM
modetm
Nov 29, 2009 10:41 PM
JaxRRevoX
Evo X Dyno Results
24
Nov 16, 2009 01:36 PM
Massappeal
Evo X Dyno Results
29
Feb 2, 2009 03:23 PM
hamx0r
18
Jul 10, 2008 06:42 PM
