JUN 264s VS HKS 280s
Old Nov 5, 2006 | 12:17 AM
EvOcHaRgeR's Avatar
Just wondering between the 2 brand of cams which would give better power and spool for a 35R? I know the jun 272s are better than the hks 280s but I am looking to use the stock ecu. Just wanting to see how the jun 264s compare to the hks 280s.....
Old Nov 5, 2006 | 12:28 AM
evobeatsti's Avatar
i heard that on aftermarket turbos the juns kick *** compared to everything else. if you are getting a gt35 you will see major power gains with the juns over the hks's. there is a guy on the forums that had juns and a 50 trim he always posts on the ams forum ask him what he thinks i think he got some of the best #'s out of any 50 trim evo ever.
Old Nov 5, 2006 | 01:00 AM
EvOcHaRgeR's Avatar
Was he using the 272s or the 264s?
Old Nov 6, 2006 | 07:05 PM
EvOcHaRgeR's Avatar
Bump for more answers
Old Nov 6, 2006 | 07:06 PM
NiteRider's Avatar
Why would you ever replace your cams and run the stock ecu?
Old Nov 6, 2006 | 07:12 PM
Spooldyou's Avatar
Why wouldnt you Run cams on the stock ECU?
Old Nov 6, 2006 | 07:17 PM
NiteRider's Avatar
because you wouldn't get the full performance of the cams as if you were running with a flash.
Old Nov 6, 2006 | 07:30 PM
dubbleugly01's Avatar
when most people say "stock ecu", they mean a flash, piggy back etc. Stock ecu pretty much means everything other than a standalone. Or at least that's how I took the original posters statement. When it comes to cams, the really high duration/high lift cams have trouble idling on MAF equipped cars, and idle better on speed density, i.e. standalone.
Old Nov 6, 2006 | 07:37 PM
Spooldyou's Avatar
Just so you know i was being wise. I think we just misunderstood. I was saying Why Couldnt you run it with a Flashed stock ECU.....
I think you ment. Just stock tune.....
Cause i was going to say... im running my 35r on a stock ECU which includes cams.
Old Nov 6, 2006 | 07:38 PM
sleet's Avatar
JUNs won't work on the stock ECU.
Old Nov 6, 2006 | 07:49 PM
boscoyo's Avatar
Come on... out with it.
Old Nov 6, 2006 | 07:50 PM
sleet's Avatar
They don't work/won't idle, it's that simple.
Old Nov 6, 2006 | 07:52 PM
boscoyo's Avatar
Why don't they?
edit: Oh, idle problems, ok thanks.
Old Nov 6, 2006 | 08:14 PM
boscoyo's Avatar
What if I go with the Tomei Procams, will I have the same problems as above?
Old Nov 6, 2006 | 10:11 PM
NiteRider's Avatar
I was going to say... Now I see, I thought it was somewhat pointless if you were running a "stock/unflashed" ECU. Well with your setup you're already putting down GOOD numbers, I would have to say JUN cams you can't go wrong. I've heard of other EVO's getting as much as 60HP on a 50 trim so I'm sure you'd be getting close to that. Now I'll know when you're talking about a "stock ECU", I learn something new everyday! YAY!!!
