EVO IX owners... Spark plug gap ?
Originally Posted by ROK EVO
Lazy asses.
Here you go;
Stock Plug= NGK ILFR7H Stock #5245 LINK
Step colder= NGK R7437-8 Stock #4901 LINK
2 Steps colder= NGK R7437-9 Stock #4654 LINK
3 Steps colder= NGK R7437-10 Stock #4655 LINK
That said, i also bought a set for stock heat ragne from sparkplugs.com. I thought that they come pre-gapped and ready to install???
Here you go;Stock Plug= NGK ILFR7H Stock #5245 LINK
Lazy asses.
Here you go;
lol.... but they do come gapped but the outside of the box i believe says .033, which is why im going to regap mine to 25 and see how they feel and if it helps with my p0301 code i throw occasionally
On the sparkplug.com website I found these
http://sparkplugs.com/more_info.asp?AAIA=&pid=8327
They are supposed to be a copper substitute for the stock plugs for the IX. but if you look at the size (reach) they are not the same as stock.
Has anyone found a copper plug for the IX?
On sparkplugs.com at the bottom there is a link for advanced tuners. I clicked on that and then I entered in the following data, which I believe to be stock plug dimension. Can some one please verify that this data is correct.
threadSize=14mm
hexSize=5/8 (16mm)
seatType=gasket
reach=26.5mm
resistor=yes
The results are found here
Link
Will all of these plugs fit an evo IX?
Which one would be a copper plug of the stock heat range?
threadSize=14mm
hexSize=5/8 (16mm)
seatType=gasket
reach=26.5mm
resistor=yes
Link
Well after reading all the stuff on NGK's website about spark plugs I think I am starting to figure this stuff out. sparkplugs.com only lists the following copper plugs that have the same dimensions as stock. the 5 or 6 seen here indicates the heat range (stock is 7). These plugs are hotter then stock and not what you want. One range colder than stock would be LFR8
LFR6A-11
LFR5A-11
LFR6C-11
The A or the C seen after the LFR6 indicates the type of tip design. I could not find much more info then (A-C) indicates special tip design, perhaps one is a V groove and another is not.
The -11 indicates the gapping.
ultimately I think I am looking for LFR8A, LFR8B, or LFR8C....I don’t really know which, the gapping they come with does not really matter.
Again these are copper plugs, not iridium like stock. I am looking for a cheap plug that can be used when I start playing around with meth and COP ignition.
LFR6A-11
LFR5A-11
LFR6C-11
im in the same boat... im looking for a decent copper plug that i can change out often. keep us posted... good work with the research
ILFR7H - OEM GAPPED AT .024" PLATINUM TIPPED ELECTRODE $11.99
LFR7AIX - SAME DIMENSIONS, GAPPED AT .028" $7.99
This is from Sparkplugs.com, the oem will last longer, but at a 33% price difference. I went with the second ones and will just change them out 10K sooner.
Back from the grave on this one...wow, 2007 post.
What have you guys found for Copper plugs that work on the IX?
Any info / recommendations on heat ranges too is greatly appreciated!
So I pulled my plugs a few weeks ago and found the previous owner had been using BKR7EIX gapped to .026...but the plugs are 7.5mm shorter than the OEM plugs!! The car was tuned by TTP at 26psi with no knock on those shorter plugs. Then I switched to the OEM plugs gapped at .024 and I started knocking. I am looking at the LFR7AIX plugs but if I was running fine with the shorter ones, I was thinking about just buying those again even though they're shorter but as long as the car runs fine I guess that won't hurt is what I'm thinking. Any opinions?
