Turbo Timer Question!
Old May 15, 2003 | 02:02 AM
DevilOnWheelz's Avatar
I need help guys... I'm about to purchase an HKS Turbo Timer off a 1995 Eclipse GS-T.... Since I can't find any Evo6 Turbo Timer Harnesses in North America... Would the Eclipse Harness work on an EVO 6? Anybody here could help me out? Thanx!
Old May 16, 2003 | 01:50 AM
r0gu3's Avatar
Contact HKS?
Old May 16, 2003 | 08:55 AM
jotan82's Avatar
i used a 95-99 DSM harness on my evo 8 and it fit fine... i believe the harness was made for the 4G63 ECU, you should be good to go
Old May 16, 2003 | 09:22 AM
Fireball's Avatar
Just put in my HKS Type 1 and used a 2g Eclipse harness (MT-6) and it works perfectly. Just clip in and off you go. If you want speed/rpm readings, pins 89 (rpm) and 86 (speed) on the ecu under the glove box need splicing.
