ARP head studs retorque??
Just got my ARP Head studs installed!! And I was just wondering If it's a good idea to recheck torque after a few hundred miles?? THANKS,,
There are many people who say retorque them after they have been heated to operating temp and cooled back down again, as this process may have loosened/stretched them somewhat. Did you replace the headgasket?
No Just head studs!! I gave it to ROADRACE to install them! I droped it off a day before....So they can install them the nextday....Cold install...
If you didn't use a new headgasket, you are already are at high risk for blowing the headgasket. Make sure you check all around the block for leaking oil/coolant. RRE knows what their doing when in comes to the 4G63. If anyone can pull off a head stud install it would be them, but this still is not the proper way to install them. Do not re-tighten the studs. If you notice any leaking around the block or steam in your exhaust, bring it back to them so they can replace the headgasket.
Ya!! I guess they have done so many this way with no issues!! So there ok with this method/// But ya I will look out for any leaks,,,anyway,,
If you set the torque wrench to the initial torque settings, it is extrmely unlikely that you will get the nut to move. If the the tension on the stud has changed slightly, you won't be able to overcome the friction in the threads. So while many people recomend chcking the torque after a few heat cycles, I don't think you'll be able to find anyone that has actually had the nuts to move, if the studs were installed properly (ARP moly lube, threads tapped and broken in, proper technique with the torque wrench, etc). I stopped checking years ago and have yet to have a HG fail without good reason since I started installing the studs the right way every time.
Interesting link = properly
http://www.posracing.net/ARPstuds.html
who ever told you that is silly in the brain. i would re trq your ARP studs every time the valve cover is off or at least once a season.
doing the 1X1 method is perfectly fine IF you know what the hell your doing. i have done 50+ sets of them without any issues. people need to learn how to work on a car before doing so.
it is an old thread for sure
FS[SouthEast]: ARP Custom Age 625+ Head Studs
hutch959
Dec 4, 2016 05:05 PM
Sheasta
Oct 29, 2015 05:00 PM
FS[West]: Arp head studs
EVO 4 life
Oct 26, 2015 08:11 PM
Rgraystone88
12
Oct 23, 2014 01:41 PM
WTB[Pacific NW]: Head studs/head gasket
BadassEvo8
Jul 31, 2014 01:20 AM
