What clutch do i have?
Old Nov 16, 2006 | 11:36 AM
vampeer's Avatar
Hello all,
Picture attached. I've bought it on eBay.
I will say later what is should be (what it was advertised as).
regards.
Old Nov 16, 2006 | 11:38 AM
Apex Racer's Avatar
Exedy single disc
hondafan's Avatar
it looks like the factory one, an exedy stg. 1, or an RRE no name.
i'd have to go with RRE no-name out of the 3 because of the way the 6-springs in the disc are set up, the factory exedy looks like different springs and the stg.1 has 4 springs.
Old Nov 16, 2006 | 11:39 AM
Ultimate CC's Avatar
why would you buy a clutch that you don't even know the name of???
Old Nov 16, 2006 | 11:45 AM
Apex Racer's Avatar
/\ I think he was mislead by the seller, but I woulod hope that it was advertised as the oem replacement or a exedy single
Old Nov 16, 2006 | 11:47 AM
vampeer's Avatar
haha, i know the name but i want to see what you guys think of it.
it was bought as exedy racing stage 1.
is there any difference (besides clamp load) from the factory one?
my old clutch was removed from the car and it looks EXACTLY the same including numbers on a pressure plate and disc.
i'm conserned if it's racing stage 1...
the box was ok (5803 item number) but it means nothing...
Old Nov 16, 2006 | 11:53 AM
Apex Racer's Avatar
Id say it is a stage one, I am not sure that exedy uses terms like racing in their descriptions however, it may have been the sellers way of hyping up the item. I would imagine the clam load etc. would be the same
Old Nov 16, 2006 | 11:54 AM
vampeer's Avatar
Angry
as far as we can see on the photo on RRE site their clutch doesn't have any numbers engraved on the outer ring of pressure plate.
and i've read somewhere out there that racing stage 1 HAS 4 springs so it looks like it is stock replacement clutch. ****!
the previous one went away after installing 3" TBE and MBC to 1,2 bar
i don't want to think what will happen when i rise the boost to 1,5 bar and cut the fuel on apexi...
Old Nov 16, 2006 | 11:56 AM
hondafan's Avatar
have you removed your clutch line restrictor pill?
Old Nov 16, 2006 | 12:01 PM
vampeer's Avatar
/\ not yet but i will ask the mechanic to do that. but i don't think it will make any difference. the clutch will engage quicer while changing gears but the previous one was slipping at 4,5 at lower RPMs
Old Nov 16, 2006 | 12:03 PM
vampeer's Avatar
does anyone have STOCK clutch picture?
Old Nov 16, 2006 | 12:05 PM
Chris@nolimitmotors's Avatar
Do you have a picture of the box it came in, or the part number. it might be a stock replacement exedy. If the part number is 05803, then its a stage one organic kit.
Old Nov 16, 2006 | 12:09 PM
tweakdsm's Avatar
Stock clutch 37K on the car :-) the car never seen track only 2autox i shift like crazy, but the car never seen hard hard launches, thats why 4-5 launches the clutch would take a **** for sure, IAM so confused about the clutch (which one to choose) and i dont want Twin disk! too much money for me......
so which clutch should i go with? who knows.
Old Nov 16, 2006 | 12:16 PM
vampeer's Avatar
go with ACT. ther are so many exedy versions and you can always buy the wrong one...
on the box it is stated 05803 but it means nothing - you can put anything in the box...
i thing i remember those 5 HARD launches mentioned earlier.... but what can you do when you are first on the lights and there is fast bike next to you
Old Nov 16, 2006 | 12:23 PM
vampeer's Avatar
i think exedy racing stage 1 should look like this. so i don't have racing stage 1 for sure... ****ing eBay scammers...
