Shifter Bushings :: Underhood or Base?
Old Nov 17, 2006 | 02:16 PM
Grey Razor's Avatar
Question Shifter Bushings :: Underhood or Base?
I really want to reduce the notchiness to my shifter (6 speed) by investing in some new bushings. I have two questions...
Which type of bushings offer the most improvement? Underhood or shifter base?
I know that you need different underhood bushing sizes for the 5 and 6 speed, but are the bushings for the shifter base a universal fit, or do they need to be made specifically for the 6 speed?
Any information would be greatly appreciated! Thanks in advance...
Old Nov 17, 2006 | 02:18 PM
tuffguy's Avatar
Underhood. Shifter is barely noticeable.
Old Nov 17, 2006 | 03:07 PM
Danny23's Avatar
you get the better results with the base bushings,but if your doing them you might as well do the 2 piece underhood also. For the extra 35 bucks or so and the half hour to put them in its worth it.there are a lot of different companys making bushings so its up to you to SEARCH and decide.
Old Nov 17, 2006 | 03:11 PM
prj.evo's Avatar
you get no results from the base bushings, its the underhood ones that go in the shift cables that make the biggest difference, imho.
Old Nov 17, 2006 | 03:26 PM
MondoBongo's Avatar
i haven't swapped out my base ones to compare, but putting in the underhood ones made a huge difference. the feel is so much better. solid during shifting, and seems smoother as well.
Old Nov 17, 2006 | 03:54 PM
Evoryder's Avatar
i'm gonna be ordering me a set of kartboys next week
urethane bushings! $48 shipped
Old Nov 17, 2006 | 04:32 PM
LV///R's Avatar
Imo after both the underhood, and shifterbase bushings were installed, you'll still have the "notchiness" . Sure its a better feel, but they are not miracle workers.
Old Nov 17, 2006 | 04:43 PM
upstateEVO's Avatar
Underhood made a big difference. Buschur aluminum bushings were $30, best bang for the buck mod I've bought yet. Less than a tank of 93.
Old Nov 17, 2006 | 04:54 PM
91TB78's Avatar
I didn't think there were any underhood or base bushings that worked on the 6spd.
Correct me if I'm wrong..I'd like to know who.
Old Nov 17, 2006 | 04:55 PM
Evoryder's Avatar
notchiness should be fixed with a good serving of BG syncroshift
Old Nov 17, 2006 | 06:46 PM
JohnEB's Avatar
I have brass underhood and polyurethene for under bushings..... if you are going to do these then go with a short throw also.
Old Nov 17, 2006 | 07:54 PM
Evoryder's Avatar
i'll throw in the short shifter too...
Old Nov 17, 2006 | 08:02 PM
hondafan's Avatar
buschur racing makes aluminum underhoods for the 6-speed and lancershop has some brass underhoods for the 6-speed.
http://www.lancershop.com/customer/p...3&cat=6&page=1
https://secure.buschurracing.com/cat...b8ce55bc9ab597
i thought the base bushings worked on either, but i'm not sure. can anyone confirm fitment on an MR?
Old Nov 18, 2006 | 04:29 PM
Grey Razor's Avatar
Cool guys, thanks for all of the info so far! Since there are two different types of metal being used for the underhood bushings (brass and hardened aluminum), I guess the big question is which metal would you recommend? Does one have a lower chance of seizing up versus the other?
Old Nov 18, 2006 | 04:41 PM
Spooldyou's Avatar
Do a short Shifter, Base Bushings and the underhood and adjust your clutch
