boost??
Old Nov 17, 2006 | 03:57 PM
highpsievo8's Avatar
boost??
don't flame me I looked many of times for this answer. how much boost can you run "safely'' on just a TBE and MBC?
Old Nov 17, 2006 | 04:14 PM
Warrtalon's Avatar
Depends on octane, tuning, altitude, and weather conditions.
You did not look long enough for your answer, I'm certain of that.
Old Nov 17, 2006 | 04:20 PM
lcakes05's Avatar
400 psi should be good.
Old Nov 17, 2006 | 04:21 PM
Wolf28's Avatar
Only if you are using meth injection
lcakes05's Avatar
go with 22psi
Old Nov 17, 2006 | 04:22 PM
lcakes05's Avatar
not even close you could never run 400 psi i was fcking around
Old Nov 17, 2006 | 04:24 PM
Wolf28's Avatar
And I was going along with your joke...
Old Nov 17, 2006 | 04:25 PM
lcakes05's Avatar
my bad lol
Old Nov 17, 2006 | 05:46 PM
warr you the man, first off. I hit fuel cut earlier at 1.5 bar so I'm lowering it to 1.38 (20ish)
hoping no fuel cut, fingers crossed
Old Nov 17, 2006 | 05:53 PM
Warrtalon's Avatar
You'll be more likely to hit fuel cut in cold weather when the air is dense, and it will happen at higher rpms in higher gears, which is where we have the most airflow across the MAF. Fuel cut is not a direct correlation with the amount of boost you're running.
Anyway, until you answer the 4 parameters I listed, we can't answer your question. Fuel cut is not what determines your safe boosting level.
Old Nov 17, 2006 | 05:54 PM
o.e.boost's Avatar
is the ecu flashed?...here in cali...(sea level)...im currently running 18lbs without a flash...i have a tbe with an evo9 turbo...
Old Nov 17, 2006 | 06:06 PM
Evoryder's Avatar
what about a boost controller?
Old Nov 17, 2006 | 06:14 PM
ApexVIII's Avatar
75 psi
Old Nov 17, 2006 | 06:19 PM
warr...93,none,sealevel,50
Old Nov 17, 2006 | 07:35 PM
Warrtalon's Avatar
Then set it at 21psi peak in 3rd gear, but be sure to get a fuel pump, recirculating BOV, and flash right away. You can probably run 22psi when you have everything.
