Transfer Case problem pics inside...
Old Nov 19, 2006 | 11:23 AM
PAPITOSMURFEVO8's Avatar
Exclamation covered
Originally Posted by eponti
why not take it to the dealer?It should be under warranty
i am amechanic i say that is aserious defect and that is a problem with the tranny parts they use or you have increase your horsepower to like 200 more with torque increase 150 than I say time for a lighten flywheel cluth/pressure plate and strenghten axles and then it can be the way you shift and drive can be the problem too. just some thing to look in to
Old Nov 19, 2006 | 11:34 AM
VRamirez2004's Avatar
already ahead of you LOL I got a lightened flywheel 10 lbs!!! and I got an aftermarket pressure plate. I dont know where to get axles but I have never heard of an evo breaking an axle? oh and yes I do drive it hard sometimes I shift very agressively when drag racing it but thats about it. I mean why have all the power not have fun with it once in a while...
Old Nov 19, 2006 | 11:48 AM
speed-demon's Avatar
definately contact Jon and send it out to Shep, they are the masters!
Old Nov 19, 2006 | 01:10 PM
good info
now that is what i am talkin about ,look at trucking spot that customs the trucks for heavy duty. they should have axles to hold up the pressure to transer the torque more to wheels and susp.and you should be able to drive hard all day like the real rally evos,just preventive maintance i rather change tires and mintor tierods and etc. pieces every 4 months then tranny parts
Old Nov 19, 2006 | 01:50 PM
smokedmustang's Avatar
You mean John at TRE correct?
Old Nov 19, 2006 | 02:16 PM
yes
yes if that is what he does i send my in couple weeks thanks guys
Old Nov 19, 2006 | 03:53 PM
GEARS's Avatar
Originally Posted by RoadSpike
I think this is the same kind of problem smokedmustang ran into,not too sure He said he broke a C clip that holds the input shaft in place. Then when it poped in it stripped out the splines on the thing.
And snapped off the snout on the front differential that plugs into the viscous coupling.
Old Nov 19, 2006 | 04:41 PM
Hey I sent you a pm! just wondering if you could answer the questions I asked. thanks!
Old Nov 20, 2006 | 03:37 AM
And yes, there is that!
Old Nov 20, 2006 | 03:38 AM
He will, I find it better to call him personally. He will do you well!
LVSBB6
Mar 4, 2011 05:32 PM
LVSBB6
Nov 25, 2010 08:40 PM
LVSBB6
Sep 20, 2010 02:44 PM
LVSBB6
Sep 16, 2010 12:11 PM
LVSBB6
May 25, 2010 05:13 PM
