Drivetrain fluid?s
Old Nov 20, 2006 | 06:46 PM
4g63t28's Avatar
Drivetrain fluid?s
First and foremost I've been doing a lot of searching, haven't really found the information I'm looking for, and I want to order fluids this week.
What are you other 5spd IX owners using for fluids? I'm skeptical about using any fluid in the trans that says not for lsd's or isn't GL-4 specific. Can I use 80-90 gear oil in the transfercase and rear diff as long as it's formulated for lsd's?
Old Nov 20, 2006 | 06:55 PM
Evoryder's Avatar
lol...no u haven't.
Do some more searching.
Old Nov 20, 2006 | 06:58 PM
Sap12687's Avatar
OEM Fluids in the Tcase (Diaqueen)
Pennzoil Syncromesh or BG Syncroshift in the Tranny
....live by them
Old Nov 20, 2006 | 07:08 PM
RoadSpike's Avatar
Hmm heard this one quite a few times you must have missed some threads.
Here's what the shop manual says:
Code:
Shop Manual:
|Lubricant               |             Specification                    |
|Engine oil              | Fully synthetic engine oils                  |
|                        | displaying ILSAC GF-3                        |
|                        | certification symbol ("Starburst"            |
|                        | symbol) or conforming to the API             |
|                        | classification SL or SL/CF                   |
|Manual Transaxle        | Gear oil API classification GL-4             |
|                        | SAE 75W-85W or 75W-90                        |
|Rear differential       | Hypoid gear oil API classification           |
|                        | GL-5 or higher                               |
|gear oil                | • Above −23°C(−10°F): SAE90,85W-90, 80W-90   |
|                        | • −34 to −23°C(−30 to −10°F): SAE80W, 80W-90 |
|                        | • Below −34°C(−30°F): SAE75W                 |
|Transfer oil            | Hypoid gear oil API classification           |
|                        | GL-5 SAE90                                   |
Old Nov 20, 2006 | 07:53 PM
4g63t28's Avatar
No, I've seriously searched this, but I'm guessing pre-05 and MR threads don't apply, I think my eyes are swollen, and my head is throbbing.
My biggest issue with this is not knowing the drivetrain constuction. So lets clear that up. Are the front and center differentials located inside the transmission like on my gsx? Do we have magnetic drain plugs?
I don't get much time to work on my car at my dealership since we can't come in saturday's and I haven't had too many drivetrain related queries so I'm a little unfamiliar with "exactly" how everything works since I haven't physically seen how it's laid out so it adds some extra questions.
If the front diff is an lsd and it's in the transmission than wouldn't the Motul300 that everyone recommends be a bad choice? Also the Motul is classified as a GL-4/5, can't the cause etching on the synchros and other yellow metals in the trans?
BG and Penn seem like a good option for the colder months, but I'm not sure they'll hold up to my canyon runs and I'm going to try to get some track days in at Lime Rock once things warm up again.
The rear diff is an lsd so it neads a lubricant with the appropriate additive's, but what about the transfer case?
So with that said...What's everyone recommending for an '06EVOIX5SPD???
Old Nov 20, 2006 | 08:32 PM
spdracerut's Avatar
go to the advance search, put in 'tranny fluid', and select, 'search titles only', then 'search now'
ElectricBlueIX
34
Mar 4, 2010 03:51 PM
krazykorean84
Nov 30, 2008 07:21 PM
05 MR
Aug 22, 2007 08:06 AM
Kierkegaard
Apr 10, 2007 07:52 PM
nightfire115
Jan 28, 2005 09:51 PM
