eclipsed evolution
Old Nov 24, 2006 | 07:35 AM
RaZoR87's Avatar
Originally Posted by MalibuJack
Another thing I had read about is the Evo ECU should plug into the Eclipse harness and work to do the job.. Then you can tune with ECUFlash, or knowing the wiring is similar, you can use an AEM EMS (though I would recommend the Evo ECU if you have to do inspections)
do you mean for the stroker swap or the entire evo swap either way its good to know
Old Nov 24, 2006 | 07:37 AM
RaZoR87's Avatar
oh and thanks for the backup malibu jack
Old Nov 24, 2006 | 07:39 AM
EvoDan2004's Avatar
The engine swap has been done before.. I know of several Eclipses, Galants, and even a Mirage DE 2 door (2000 or 2001??) that had been done.. The drivetrain is a different story, and quite a bit more involved, but I would say to start with the engine swap, then plan out a driveline swap later since thats the hardest part.
ok but going with an evo 8 motor to an older style or even a new style eclipse the motors dont line up and the evo motor is in a 180 degree spin. a galant i see it being much easyer in. not an eclipse
he said he wants an evo 8 motor in a 91 eclipse.
Old Nov 24, 2006 | 07:40 AM
EvoDan2004's Avatar
i say the galant becvause you can grad an older evo motor and slap it right in. the galants are there older evos. much easyer to work with
Old Nov 24, 2006 | 07:42 AM
RaZoR87's Avatar
FWIW This should be a fairly straightforward swap, however I might recommend doing the "2.4 stroker" that is commonly done using the eclipse block, and using an Evo head, turbo, etc.. This would be the easiest as you should already have a usable short block.. Just remember it needs to be built the right way.
yes the right way not really wanting to take the chance that head swap just does sound very dependable and yes i know its been done alot but i think ill just stick to the safe side lol i might go for th 2.3 stroker upgrad one day though if every thing works out right
who knows i may just keep my 4g64 after the swap and fully build it into a 2.4 DOHC beast lol it be a slow as i go process if i did do it
Old Nov 24, 2006 | 07:44 AM
RaZoR87's Avatar
galants have the same motor and orientation as a 3g eclipse lol and the evo IV through VIII has the same orientation as ours the evo I through III three though have the opposite orientation that you are talking about
Old Nov 24, 2006 | 07:46 AM
MalibuJack's Avatar
Actually his first post says an 01 eclipse.. Which the drivetrain is oriented the same as ours.. The Eclipse from 2000-2005, Mirage 2000-2002, Galant after 2000 with the 4G64 engine (mirage has a 1.5 engine, but is similar) all share quite a bit.. A built 4G64 short block is basically the Eclipse block with the Evo oil squirters, and some builders have been offering this for some time for the Evo..
So it stands that logically you can do the opposite with an Eclipse..
99 and earlier Eclipses are not the same car.. their a different animal..
RaZoR87's Avatar
check that agian i said a 01 as in 2001
but in the aspect of a 91 eclipse you would be right so i see what your saying
Old Nov 24, 2006 | 07:48 AM
EvoDan2004's Avatar
i fix my statment. i thought i saw 91. sorry man. its befor 1030 when this started cut me some slack. i just got up. lol
Old Nov 24, 2006 | 07:49 AM
RaZoR87's Avatar
you know if you buy just the evo long block (no ps pump, alt, ect ect) then you can get them for like 1000 2000 dollarsi even found some for 900
Old Nov 24, 2006 | 07:50 AM
MalibuJack's Avatar
Once you have the equivalent of the "Evo Engine" you probably want to run the evo ECU.. the harnesses are nearly identical, same with the solenoids and actuators on the engine, if you swapped in the Evo intake manifold, sensors, throttle body, MAF, coils, etc.. It all should plug right in.. Makes sense to use the ECU also.
RaZoR87's Avatar
lol i fully understand
Old Nov 24, 2006 | 07:52 AM
RaZoR87's Avatar
wow thanks man thats one less thing i wont have to find. sooner or later if i decide to do some moding to the engine ill get the aem ems but for now i think the evo ecu will be fine
Old Nov 24, 2006 | 07:53 AM
MalibuJack's Avatar
Yep, I picked up my backup short block for $500 and head for $250 (if I remember)
You'll find most of the engine accessories should bolt right onto the Evo block anyway.. The things that would be different are the timing belt covers and whatnot.. I think most of the existing engine accessories are located at or below head level, and should bolt right back on without any issue. You might have to use an Evo PS pump and a/c compressor though (if the offset or size of the eclipse one) interferes with the turbo, FWIW it shouldn't.
Old Nov 24, 2006 | 07:58 AM
RaZoR87's Avatar
lol you know what all the guys that have done this swap wont even talk too me about but you've proved to be more of a help in one thread than them and you havent even done the swap lol
what do you use that long block for
