act clutch
Old Nov 27, 2006 | 04:59 PM
Apex Racer's Avatar
I do experience some chatter at low speed or when slowing quickly
Old Nov 27, 2006 | 05:02 PM
Pure Playaer's Avatar
i have the act pressure plate, 6 puck unsprung, and prolight flywheel.. n i like it alot
Old Nov 27, 2006 | 05:30 PM
Danny23's Avatar
i had an excedy twin in my 03. Does anyone have any idea of the weight of that flywheel as compared to the act prolight flywheel?
Old Nov 27, 2006 | 06:48 PM
RenEvoIX's Avatar
Originally Posted by andifidie
I got that clutch, and flywheel and im lovin it:-)
ACT street clutch is def a good.. since u got a evo ix u should ve got a exedy twin disk.. my car has 345whp & 357 ft-lb on buschurs dyno,, last time i went to da drag strip it started smilling. the clutch did handel the torque but dunno if it ll handel any more torque than wot i have now.. soo if any one has a ACT street clutch n running more or close to 380-400 ft-lb of torque plzz let us know coz im thinking of changing the clutch next year..
Old Nov 27, 2006 | 06:51 PM
dsmfan95's Avatar
I'm running the ACT HDSS clutch and I put down 416wtq and it's held so far.
Old Nov 27, 2006 | 07:04 PM
EJEvo's Avatar
The Exedy twin disc is a pretty small diameter flywheel, but it weighs a fair amount. If I remember correctly, the whole clutch package weighs around 38lbs, so I'm going to guess it's in the neighborhood of 7-9 lbs.
Old Nov 28, 2006 | 01:38 PM
RenEvoIX's Avatar
416 wtq is it on a dyno jet or a mustang dyno.. my 357 is on a mustang dyno n thats something like 428wtq on a dyno jet..
Old Nov 28, 2006 | 02:12 PM
Danny23's Avatar
I ordered the act clutch with the prolight flywheel from Chris at nolimitmotors and he told me there will be NO driveability issues with the flywheel. He told me they have put them in plenty of street cars with no problems at all. I talked to him about some of the negative feedback i got about the flywheel and he told me to trust him as i will have no problems. The difference in weight is about 4 pounds between the streetlight and prolight flywheel. EJ evo just said that the excedy flywheel he figures is about in the neighborhood of 7-9 lbs. The streetlight should be about the same weight as the stock flywheel which from what i hear is about 12 lbs. (i,m not sure about that weight,its just what i heard from other evom members)So if the excedy is around 7-9 lbs then i,m guessing the prolight should be around 8-9 lbs. I had an excedy twin in my 03 with really no problems once i got used to it. So i,m guessing that the prolight at 8-9 should be fine. I spoke to ACT man and he also said i should have no problems at all.Once its installed and broken in i,ll let everyone know what the deal is.
Old Nov 28, 2006 | 02:34 PM
t51splbb's Avatar
StreetLite is 13.1 lbs & Prolite is 10.1 lbs.
Old Nov 28, 2006 | 03:06 PM
dsmfan95's Avatar
Mustang Dyno.
Old Nov 28, 2006 | 03:14 PM
EVIL MR's Avatar
NEED A PM to 32828
Originally Posted by Chris@nolimitmotors
The ACT clutch kit is a great, it will handle anything the stock turbo will throw at it, even most bigger turbos also. Shoot me a pm if you need one, we have them in stock and have a great price.
Thanks,
Chris
Old Nov 28, 2006 | 03:15 PM
TxEvo8's Avatar
I have had the ACT for two years and over 40k miles, awesome clutch!!
Old Nov 28, 2006 | 03:21 PM
MRadjahoe's Avatar
Act w/o the flywheel n got 50,XXX miles on it and still goin!
Old Nov 28, 2006 | 03:26 PM
Danny23's Avatar
if the prolight is 10.1 lbs. then i should have absolutely no issues whatsoever.
Old Nov 28, 2006 | 03:31 PM
MitsuJoe's Avatar
I think you will be alright with the Prolight, I thought it was lighter....
The Exedy MF04 is 11.2 or 11.9lbs and that one is not that bad to drive.
Let us know how you like it!
