stroker vs turbo
Old Nov 28, 2006 | 11:51 AM
williamw1192's Avatar
stroker vs turbo
I am looking to upgrade my engine and I am not sure if I should do a 2.3 liter stroker kit first or just go with a 50 trim turbo instead. i know I will make larger numbers with the turbo but would it be wiser to do the stroker then a turbo upgrade down the road? thanks
Old Nov 28, 2006 | 11:54 AM
Jax419's Avatar
Yea I think it would be better if you build your motor first, then you wouldnt have to worry about things breaking as much..but then again your going with a 50 trim and Im sure there are a bunch of people running that turbo on a stock block..
Old Nov 28, 2006 | 11:57 AM
4Gsixty3's Avatar
how many miles u have on yr motor? if it doesnt require a rebuild, i will go with the 50trim first.
Old Nov 28, 2006 | 11:59 AM
WrX Kila's Avatar
Go for the turbo, you can make 450whp with the 4g63 without a sweat!
Old Nov 28, 2006 | 12:03 PM
I have only 24k miles. I have alredy done exhaust, ecu, boost control, and cams just looking to make the next step
Old Nov 28, 2006 | 12:12 PM
ONRAILS's Avatar
why not. FMIC/Pipes. DV. Injectors. Alky.
Old Nov 28, 2006 | 12:21 PM
I was told to wait on the FMICwhen I do the turbo upgrade. I have already replaced upper and lower pipes
Old Nov 28, 2006 | 01:01 PM
ONRAILS's Avatar
You'll need it when upgrading. Might as well do it before. Also i'd look into a alky kit and injectors first. are you on stock bpv
Old Nov 28, 2006 | 01:21 PM
BenjyJ's Avatar
you will need injectors when you go with the turbo kit.
I definitely think that you will see better gains with a turbo.
I have the 50trim on a bone stock block with GSC 272/272s on pump gas and the car is a blast to drive on the street.
Old Nov 28, 2006 | 10:16 PM
srt4-Joe's Avatar
Depends on how much power you plan on making. I would go with the .50 trim and the basic bolt ons. Unless you plan on make above 500 then I wouldn't worry about engine rebuilds.
Old Nov 28, 2006 | 10:22 PM
HPF Kyle's Avatar
50 trim with supporting mods all the way.
Most engines fail not because of mechanical limitations, but because of an inadequate fuel system or poor tuning.
Old Nov 28, 2006 | 10:29 PM
srt4-Joe's Avatar
Exactly, make as much power as you want, but if it isn't safe then why bother. User error not mechanical
Old Dec 1, 2006 | 01:19 PM
I am only looking to make 450 to 475hp. I know I will have to replace the injectors,FMIC,probably fuel pump.
Old Dec 1, 2006 | 02:09 PM
Kee1pride's Avatar
will a 50 trim with a 2.3 stroker spool the same as stock?
Old Dec 1, 2006 | 02:20 PM
Jax419's Avatar
^^? That would be nice thugh!
