Jun Lash Killers
Old Dec 5, 2006 | 06:19 PM
Mase's Avatar
Jun Lash Killers
I'm curious to know if anyone runs the JUN lash killer solid lifters on their 4g63.
I received a set of these along with the JUN cams and JUN stroker kit they sent from japan. There is no documentation that came with them as to what valve lash clearance they are suppose to have. They came with shims that i have put in when i first assembled the motor, but they appear to be too tight.
I emailed JUN with no luck, they want me to ship the head, which is a brand new cosworth head, and im not about to ship it all the way to japan.
My next option is to try without the shims or try shims from different applications (nissan shims appear the same diameter but different height)
If anyone has had any experience with them, id greatly appreciate it.
Regards,
Mase
Old Dec 5, 2006 | 07:48 PM
HPF Kyle's Avatar
bump for an awesome tuner. No idea mase.
Old Dec 7, 2006 | 06:14 AM
ZyBeR's Avatar
I have the specs from JUN some where... I can try to find them for you if you like.
Could you please post pictures of the lifters and shims, I'm going to get a set of those. I tries BLE but they was just garbage! Three of the came loose and almost killed my Cosworth head.
Old Dec 7, 2006 | 06:20 AM
ZyBeR's Avatar
Found it.
JUN recommend 0.15mm clearance on both int. and ext. side.
Old Dec 17, 2006 | 06:27 PM
Mase's Avatar
Originally Posted by Reine
Found it.
Nice, thank you, i had talked to Tomei at PRI. their solid lifter kit called for a recommendation of .12 and .14 mm.
Shoot me a PM, we will talk more
but i appreciate your help.
Regards,
Mase
Old Dec 17, 2006 | 11:49 PM
ZyBeR's Avatar
Regards,
Mase
You got pm
Tw3NTy0n3
May 21, 2016 11:24 PM
popadel
Jul 11, 2008 03:26 AM
Mase
Mar 3, 2007 08:50 PM
Yuya@BP
Jan 13, 2007 07:46 PM
AlwaysinBoost
Dec 28, 2006 05:45 AM
