Noisy breaks
Old May 19, 2003 | 09:47 PM
IS2000's Avatar
Noisy breaks
Are those Brembos supposed to be a little noisy when you apply the break? The breaking systems on my last 2 cars didn't make as much noise.
I'm a little paranoid since a lady hit my right front fender on Saturday morning. I'm sure there might be some impact on the tire, since the alignment is slightly off spec. I was also on a full breaking and I could feel the break pedal vibrated on the impact. Do you think my passenger's side front break is okay?
Old May 20, 2003 | 12:58 AM
IS2000's Avatar
Well, just a question then.
Does your break pedal vibrate under full breaking?
Old Jun 9, 2003 | 12:37 AM
EVOLUTIONIZE's Avatar
My Brembos are loud too i think its normal though, . If ur talking about the same kind of vibration u get from bad rotors the answer is no.
Laterz
Old Jun 9, 2003 | 12:51 AM
pumpdog720's Avatar
It's normal for all brakes to squeak.
Old Jun 9, 2003 | 12:51 PM
degrootdd's Avatar
Did you see the TSB put out by
Here is a copy for your viewing pleasure
SUBJECT : BRAKES BREAK-IN / BRAKE NOISE DIAGNOSIS No: TSB-03-35-002
DATE: February, 2003
MODEL 2003 Lancer Evolution
CIRCULATE TO: [ ] GENERAL MANAGER [X] PARTS MANAGER [X] TECHNICIAN
[X] SERVICE ADVISOR [X] SERVICE MANAGER [X] WARRANTY PROCESSOR [X] SALES MANAGER
PURPOSE
Lancer Evolution uses high-performance brakes for stable control when driving at high speeds. If the customer does not follow the recommended break-in driving precautions, premature brake wear and brake noise will result. Instruct your customers that it is very important to observe the break-in driving precautions during the first 300 miles (500 km), after brake pads have been replaced, and after brake disc resurfacing.
This bulletin contains Lancer Evolution break-in driving precautions and brake noise diagnosis and repair information.
AFFECTED VEHICLES
PROCEDURE
BREAK-IN DRIVING PRECAUTIONS
During the first 300 miles (500 km):
•Avoid high speed driving (over 70 mph [112 km/h]).
•Avoid sudden and hard braking.
•Avoid continuous braking when driving on hills and curves. Instead, shift to a lower gear to avoid as much foot braking as possible.
Diagnose loud brake noise as follows:
1.Remove the tire and wheel assembly.
2.Confirm that the brake pad and disc are properly installed.
3.Inspect the shims:
a.Check for warped shims. Replace as necessary.
b.Check for proper shim installation. Correct installation if necessary.
4.Inspect the brake pad for grease or contamination. Clean as necessary with brake cleaner.
5.Inspect the brake pad surface for evenness. If necessary, even the surface by using 80-100 grit sandpaper.
6.Inspect the rotor for rust, grease, or contamination. Correct as necessary.
7.Inspect for lack of grease between the brake pad and shim. Apply grease as necessary.
8.Reinstall the wheel and tire assembly. Use a torque wrench to tighten the wheel nuts evenly to
98 + 10 Nm (73 + 7 ft/lb) in diagonal order.
9.Test drive the vehicle. If the brake noise continues, resurface the disc, using an on-car brake lathe.
If brake disc thickness is less than 29.8 mm (front) or 20.4 mm (rear) after resurfacing, replace the disc.
10.After resurfacing, reinstall the wheel and tire assembly and test drive the vehicle again. If the noise is still not eliminated, replace the disc.
WARRANTY INFORMATION
Normal warranty procedures apply.
Mitsubishi Motors North America, Inc.
1999VR-4EVO
Nov 11, 2016 07:48 AM
Ferp
Sep 28, 2016 11:40 AM
MitsuJDM
21
Sep 9, 2011 05:07 AM
Nichiren
Lancer Troubleshooting
Dec 10, 2009 11:34 AM
