Phenolic Intake Manifold Gasket...anyone use this?
I will be replacing the Intake Manifold soon and I was wondering if anyone has used an Intake Manifold spacer such as the one shown below? Any reviews, otherwise I will be going with the stock gasket.
http://www.vividracing.com/catalog/p...ducts_id/29706
Thanks!
Thanks!
Yes, it does. I have the Hondata version, and it works great.
Depending on the ambient temperatures, How long the car has been running, etc. and if dogs and cats are living together, I have with my pyrometer measured at a MINIMUM a ~20 degree difference in head temperature vs intake manifold temperature. The temp's were taken just above the gasket about 1/2", then on the intake manifold about 1/2" away from the gasket. After installing it, I did notice a subtle difference in my recently calibrated a$$ dyno. I have taken readings with the car at operating temperatures just after driving, and idling for a few minutes, etc... I must admit, I was impressed.
Is it worth the ~$50 I paid for it? Yes. Was it worth the install? Umm, well the excessive amounts of beers and loud obnoxious music made it a little better. Getting that manifold off was a bizzatch.
No you shouldnt have to use longer studs. You need a new gasket when you take the manifold off so you might as well just buy a hondata one. They have been dyno pruven to work and people with hondas have been using them forever. if you need one we have them in stock, there $58 shipped.
Thanks,
Chris
Thanks,
Chris
I dunno. I changed all mine to SS studs, all around the head. Exhaust studs, manifold studs and a few others. So, I never knew if the factory stuff would work.
Thanks,
Chris
Thanks,
Chris
Good price...anything else I can do besides porting the IM to help anything?
Any tips to taking off the IM any easier?
Not that I trust Ebay but obviously there has been some problems with the Hondata gaskets per this auction?
http://cgi.ebay.com/ebaymotors/ws/eB...m=330060879047
I have been using the Hondata version on my B18C since '01 and it works wonders for lowering the IAT. I did not use a gasket because the spacer, in essence, is a thick gasket. I saw at least 20* temps drops whenever I datalogged.
I used the Hondata IMG on my K20A2 and I can honestly say that IAT temperatures were much lower. I monitored the temperatures via K-Pro (Programmable ECU) and saw significant changes in temperatures during stop-and-go traffic as well as at cruising speeds.
-Carl
-Carl
