Hallman Evolution MBC help.
If I didn't buy the Hallman "short" kit that is designed specifically for the Evo, will I have to cut my Hallman Evo MBC to make if fit? I guess the short kit for the Evo is 20 inches shorter than the kit that I have. help please.
locate where you want to mount the boost controller in the engine bay, locate where you want to mount the adjustment knob in the cockpit, and drill a hole for the cable in the firewall that is convinient, and is pretty much a straight shot from the mbc to the adjustment knob. once you get things mounted, it's easy to see how much of the cable needs to be cut out. Leave a little bit of a curve in the cable in the engine bay so that you don't cut it too short! To short and you're screwed, too long and your loop is just a bit bigger. I used a dremel, but a hacksaw will work. Here's pics of mounting locations.
Yeah, just stretch it out. The instructions should say something about a minimum bend radius. The tighter the bend, the more force it's going to take on the adjustment knob to turn it. It's a pretty smooth and simple operation though, even with a fairly radical bend in the cable. Drilling the hole in the firewall is the hardest part.
