evo8 block in evo9 ? who has done this?
Old Dec 15, 2006 | 10:46 AM
94AWDcoupe's Avatar
Anyone here build and evo8 block and install it in evo9? What needs to be done to get oil to the mivec? Called Buschur and AMS but they havent done this yet. jacksonauto says they have customers that have done this but couldn't say what was done exactly since they themselves have not done it.
Also does anyone know how thick the evo9 gasket is? The evo8 gasket is very thin. Looks like a compressed thickness of just .026.
Old Dec 15, 2006 | 09:40 PM
Steve@NoLimitmotors's Avatar
Ricky at TopLevel in NY has an evo 8 motor in his evo 9. Full evo 8 motor/ecu/harness with aftermarket pistons and rods. sounds like you just want to use the block and I think its the same but i'd have to with him
Old Dec 28, 2006 | 01:47 PM
94AWDcoupe's Avatar
Found the answers to my own questions. The evo8 and evo9 block are the same. The headgaskets are interchangable. The evo8 gasket is .026 and the the evo9 is .040. The mivec gets its oil from the oil pressue sender fitting on the back of the block. There is an extra fitting there under the oil pressure sender. That fitting just needs to be swapped when installing the shortblock.
Old Dec 28, 2006 | 01:55 PM
EVIL_EVO_VIII's Avatar
why are you putting a VIII motor in a IX?
Old Dec 28, 2006 | 02:16 PM
EvoAnthony's Avatar
So can we put a 9 mivec head on an 8 then?
Old Dec 28, 2006 | 02:20 PM
tuning g's Avatar
Thanks for the info it's always good to know this stuff
Old Dec 28, 2006 | 02:22 PM
4WS Tuning's Avatar
i dont see why you cant put the 9 head on an 8
i read a few articles somewhere that all the super high hp cars in europe, japan etc.. have been swapping back to the evo 8 head cause they said the 9 head was hurting more than helping in big turbo applications..
Old Dec 28, 2006 | 02:25 PM
^I read the same thing
Old Dec 28, 2006 | 02:27 PM
caswanso's Avatar
^^^^Interesting^^^^ I wonder why?
Old Dec 28, 2006 | 02:30 PM
4WS Tuning's Avatar
the mivec is suppose to aid smaller quick spooling turbo's... but with a larger much slower spooling turbo it has no effect and is just an added complication.
i think once companies like jun, revolver and the other top end guys come up with better cams that are equal to the cams you can find for an evo 8 there will be better results..
Old Dec 28, 2006 | 02:32 PM
UpstateEVOVIII's Avatar
Look at Honda/Toyota/ect. ect....anytime you come in contact with a high hp vehicle the variable valve timing becomes a setback. I don't know the mechanics behind it so unfortunately I can't indulge beyond that. VVT is very good to make more power from less to a certain point. From that point forward you ultimately need a non-VVT head to make greater power numbers. As all Honda owners hate to remember the fastest ones to date are non-Vtec
Old Dec 28, 2006 | 03:15 PM
4WS Tuning's Avatar
thats true... all my honda engine swap friends that wanted to go turbo went with a regular LS b16 instead of opting for the vtec...
good point
Old Dec 28, 2006 | 03:45 PM
steelcityevo8's Avatar
good point
yeah they do the LS block with B16 head. the head is a vtec head. maybe full racing applications work better without vtec being used. but the vtec heads flow way better than non vtec. i am almost positive u can use a vtec head without utilizing vtec itself
Old Dec 28, 2006 | 03:57 PM
mot's Avatar
mot
toda vtec killer camshafts eliminate it
from what i remember its just another lobe on the cam that they dont add on or something like that
Old Dec 28, 2006 | 04:14 PM
Huy's Evo's Avatar
thats true but all of honda motors and toyota's celica GT and GTS are aluminum. they are not designed to boosted and the high compression of these motors cant handle 12 pound daily with out something give out. Also LS motor are cheaper then a vtec motor by $2000 and easier to tune because u dont have to make multi maps when the cam timing or lifts changes. the vtec heads do flow better but the bottoms are not strong enough.
it cost alot of money to keep the cam timing and lift, lots R&D and tuning. most newer cars out there like the bugatti has made lots of power with the cam timing and lift. pretty much every car company has started using the same technolgy honda and toyota been using it is just what they call it that throws ppl off.
