just got an 03 evo , want like 350 hp?
Old Dec 17, 2006 | 03:17 PM
Ct9aGsR's Avatar
buschur racing turboback
hks racing suction intake
255 pump
reflash
ams upper and lower intercooler pipe
dc exhaust manifold
buschur o2 housing ported
sun auto ignition box
and maybe some rc 650cc injectors.
and run like 22psi
is it possible with setup?
let we know wat u guys think....
Old Dec 17, 2006 | 03:31 PM
yellowEVO21's Avatar
yes...add cams , 10.5 hotside, and a front mount and you should hit that...although if you're running the stock turbo, you won't need the ignition or the injectors.
Old Dec 17, 2006 | 03:34 PM
voodoo23's Avatar
I see alot of wasted money in that list. You will need to throw some cams in there to get you in the 350 range.
Old Dec 17, 2006 | 03:38 PM
SIGSP2340's Avatar
Do the Buschur 1 through 4 stages. You will be glad you did.
Old Dec 17, 2006 | 03:47 PM
scheides's Avatar
EvoM Moderator
350 whp or 350 crank hp? Exhaust, Intake, fuel pump and cams and you'll be good to go (with a flash).
Old Dec 17, 2006 | 05:27 PM
TeamTurtle's Avatar
If you want whp, then +1 with the BR stages. Stage one puts you at 330whp already.
Old Dec 17, 2006 | 05:33 PM
MYEVOVIII's Avatar
For an VIII all you need is TBE, MBC, Cams, Drop in K&N, Tuning and your there. Even less if you had a IX
Old Dec 17, 2006 | 05:49 PM
riceball777's Avatar
i also have a 03 evo
i'm making 315whp. 3" tbe, hks 272 cams, hks rs intake, boost controler set to 20psi cuz of crappy 91 octane
Stockevo9ssl
May 5, 2015 12:45 PM
ChicagoEvo9
Sep 25, 2014 01:42 PM
Ronnie Size
Jul 28, 2014 05:28 AM
EvoIIIAj
May 31, 2014 09:15 AM
EvOcHaRgeR
Apr 13, 2014 07:34 PM
