is it the throw-out bearing?
Old Dec 20, 2006 | 02:25 AM
feautoevo's Avatar
wow, honestly it sounds like you ran out of fluid in the slave syl, did you try to pull the pedal off the floor when you turned the car off? I just really hate to see you go through all this work because you needed more fluid, *** ALSO anyone who has bled the clutch system can tell you just because the fluid LOOKS and reads full does not mean that your slave cyl line is getting any fluid, you have to litterally OVERFILL the resivior to be able to suck in any fluid or you will be left bleeding nothing but air, ooh I think I have a helpful link...
http://evomoto.com/tech_info.php?tPa...67b7c7e4e11230
