AFI Turbo Kit Installed
Old Feb 6, 2007 | 08:09 AM
  #31
Evo8Master's Avatar
Originally Posted by precisi0n
Here ya go
Still have to send a couple things to get coated... but you get the idea
How does she idle with the Gsc 280 cams and flash? Nice numbers
Old Feb 6, 2007 | 06:52 PM
  #32
precisi0n's Avatar
Well, as promised, here it is....
Old Feb 6, 2007 | 07:47 PM
  #33
precisi0n's Avatar
I like the chunky idle
Old Feb 7, 2007 | 12:22 PM
  #34
riceball777's Avatar
what kinfand size turbo was this???
also how much power does it make on pump gas alone at about 20-21 psi
Old Feb 7, 2007 | 12:32 PM
  #35
KartaRailed's Avatar
Made 511 on a dynapack dyno none the less, I thought for sure I was gonna see dynojet, dynopacks read quite low in comparison, not as bad as a mustang, but down there. Good one, and the mani design looks cool as shat.
Old Feb 7, 2007 | 12:52 PM
  #36
many many dyno packs read the same as dyno jets. some even read lower
Old Feb 7, 2007 | 01:30 PM
  #37
AFI Turbo's Avatar
Most of the dynapacks out here seem to read lower than the local dynojets. Either way numbers are just that, numbers.
Old Feb 23, 2007 | 08:17 PM
  #38
matyb's Avatar
yea it was your thread, and yes im still stalking thiis set up i postted the thread you rsponded to. well i hope to buy this kit soon. as promised i'll let you know the results
Old Oct 18, 2010 | 03:43 PM
  #39
ryukinevo's Avatar
Unhappy
UPDATE: The turbo kit and IC piping is done except for the coating. Dyno sheet and updated pictures on page 2/3. AFI's name on the forums is AZ-FI. If you have any questions, Jesse can answer them. They have bent over backwards to take care of me, as they will anyone who buys anything from them. I also have to give credit where credit is due for the tuning. Al has done it again . Thanks alot for the tune. I will be needing your services again once I get the rest of the motor done...
I know this is a long shot because this is an old thread, but I need help on making lines for this kit.
For some reason AFI Turbo makes everything for a kit, except they do not have information for the oil lines and water lines anymore.
Garrett Turbo has only distributors to call and no phone# for oil line specs on there GT35R.
Do you still own the car and the kit? Do you have any idea what was installed with this kit?
I would like to replace all the factory lines with the right -AN spec for this GT35R.
2JZfan
For Sale - Wheels / Tires
Aug 20, 2009 11:39 AM
alfredob1
10
Jul 22, 2009 05:56 AM
Jhero23
43
Sep 7, 2006 06:18 PM
blue rocket
29
Feb 9, 2004 01:12 PM
