50 shot on evo 9?
Old Dec 24, 2006 | 12:45 PM
turbo speedy's Avatar
50 shot on evo 9?
if i put a 50 shot on my car think it will be safe? i have a friend with a srt-4 and on his fuel rail it has a trader valve stock do the evos have that also or do we have to cut the fuel line?
Old Dec 24, 2006 | 12:58 PM
Silk's Avatar
Dont do it
Old Dec 24, 2006 | 01:03 PM
adrenaline1's Avatar
i'll just say the neon turbo block can handle juice very well and gains insane torque from it. i'm sure if u tune it WELL it should be ok. i'd research as much as possible first.
Old Dec 24, 2006 | 01:11 PM
ONRAILS's Avatar
just get an aftermaket fuel rail.
there will be no need to tune for a 50shot becides using the correct jets. Most people on here don't know what their talking about so ingore them.
Old Dec 24, 2006 | 01:18 PM
Danny23's Avatar
theres more to putting on nitrous then just installing it. Wet system, dry system, do you have an upgraded fuel pump etc. Its your car but i wouldnt use nitrous unless i had a very large upgraded turbo with supporting mods. And the only reason i would use it then is to spool the turbo faster. And then i would still only use a 35 shot.Good luck!
Old Dec 24, 2006 | 01:26 PM
i have a manifold o2 housing turbo-back uicp and licp turbo xs intercooler walbo 255 fuel pump and a reflash
Old Dec 24, 2006 | 01:30 PM
ONRAILS's Avatar
well obviously in his post hes talking about a wetsystem because hes talking about T-ing a fuel line.
And in this situation nitrous is its own fuel.
Old Dec 24, 2006 | 01:34 PM
are u kidding me? i wouldnt comment on the neon unless i owned and knew about it kthx. please install a nos kit blindly on ur car with just the 'right' jets and lmk how it goes. i recommend a 400 shot. im sure ull run 8s with the faster awd.
Old Dec 24, 2006 | 01:35 PM
Ph3n1x's Avatar
Don't do it.
If you do it, I cant wait to see your "Oh noes, I blowed up my Engines" thread
Old Dec 24, 2006 | 01:46 PM
rhds13's Avatar
dooooooooo it!!!!!!!!!!!!
Old Dec 24, 2006 | 01:52 PM
inco9nito99's Avatar
I'd say the 50shot is perfectly fine...you have supporting mods, but me personally i'd run a dry system with upgraded fuel injectors -that way you don't have to splice anything into the fuel rail. Tune via ecuflash for richer conditions under WOT and while squeezing. Oh and make sure you run colder plugs..
Old Dec 24, 2006 | 02:04 PM
Dr Evo's Avatar
For God's sake, please don't do it. And this is coming from a previous Evo 8 owner who SPRAYED. It may work the first few times but then the car rewards you with numerious problems.
I now drive an Evo 9 and I have NO plans whatsoever to spray the happy juice.
Remember... Bottle is for babies, real men get blown!
Old Dec 24, 2006 | 02:09 PM
ONRAILS's Avatar
how much did you spray? Dry or Wet.. if it was dry did you have upgraded injectors?
Did you have a bottle warmer and monitor your bottle pressure?
did you have headstuds? did you always spray on race gas? just some ?'s
Old Dec 24, 2006 | 02:34 PM
superflyevo's Avatar
50 shot is nothing id recomend a fuel pump
but go for it
Old Dec 24, 2006 | 04:21 PM
Danny23's Avatar
your right, it just went over my head. If you do the no2 i would recomend the zex nitrous kit.I know two people using them,one on a honda the other is on a 03 evo. I would consult with Al(dynoflash)on this as he use to have the zex kit in his evo.
