Electronic boost controller
Old Dec 26, 2006 | 12:38 PM
ries's Avatar
has anyone had any experience w/ the AEM Truboost boost controller???
Old Dec 26, 2006 | 03:41 PM
smitty1119's Avatar
No experience, but I am going to order one up...
Old Dec 26, 2006 | 10:17 PM
fromWRXtoEVO's Avatar
Originally Posted by kreionic
Another happy profec B spec II user that loves it. Boost stays very consistant even duiring winter I do not need to lower the boost
Not to contradict your comment but the main difference between the MBC and the EBC is that, the EBC boost would not be altered regardless or temperature of altitude, it would compensate no matter what.
On the other side, with the MBC, the engine will physically produce more power/boost with lower temps and will push the ceramic ball mechanism(if applicable) harder ultimately altering the boost control (taper/fluctuation).
In other words, what you are saying is known performance to be specific to the EBC.
Carlos
Old Dec 27, 2006 | 08:44 AM
Cirrusly Evolvd's Avatar
That is the worst part about MBC's...most that I've seen are crappy at holding a steady boost pressure. Whereas a solenoid can rapidly close or open to maintain a constant psi.
Old Dec 30, 2006 | 10:36 PM
Leshiye's Avatar
Apexi SAFC II
I have the Apex-i SAFC-II installed on my 04 8. I had it installed before I did anything else along with a D-Jetro Apex-i Power FC stand alone unit. The boost is very consistent throughout the power band. I would recommend it for those that are doing more than just an intake and exhaust. For the price and the reliability, I can think of nothing that makes more sense.
Old Dec 31, 2006 | 02:18 AM
Profoxcg's Avatar
What are the differences between the HKS EVC 6 and the apexi AVC-R ?
Do i need a boost gauge anyway after installing either? does one do more than the other?
Old Dec 31, 2006 | 02:27 AM
Profoxcg's Avatar
okay correct me, but I think the AVC-R has more and better features?? not to mention i can display more information, and i guess with either on unit i do not need a boost gauge?
does anyone have pics of either of these installed in their cars interiors?
Old Dec 31, 2006 | 08:35 AM
You don't need a boost gauge with most EBC offerings. The AVC-R does have a lot of options but consider what you're really using it for. Do you really need gear dependent boost levels? Are you that serious of a racer to require all it's features or do you just want it because it looks cool and has all those features?
There are a lot of other products that cost nearly half as much as the AVC-R and work perfectly.
Old Dec 31, 2006 | 08:40 AM
DRFTKNGG's Avatar
TURBOSMART....E-BOOST 2. One of the most expensive but one of the most capable. With all the meth kits, NOS, this controller can easily handle anything you throw at it!
DRFTKNGG's Avatar
Power Enterprise Boostgauge/Boost controller works well for the basic function of controlling boost.
Old Jan 15, 2007 | 12:25 AM
evoracingstar's Avatar
Go with the Greddy Profec B spec II its the best love it! just need to read before u use it or have someone show u how to use it.
Old Mar 4, 2007 | 04:55 AM
alexlewand's Avatar
I have Apexi AVC-R and love it. Hold boost just is hard to setup and install.
Old Mar 7, 2007 | 10:51 AM
SlowEVO_Mr's Avatar
Which EBC with the option of "plug and play"?
Old Mar 7, 2007 | 07:33 PM
SlowEVO_Mr's Avatar
Old Mar 7, 2007 | 07:53 PM
DJ Brett B's Avatar
I am considering the Greddy profec-S or spec B after I pick up my aquamist HSF-5 meth kit in a couple weeks. both in the $250-350 range and both great EBCs
